Page 2 of 2 1 2
#1370463 08/31/05 04:26 PM
OK I am confused, how does that work? I just used a giant screw driver.
Rich S
1998 SVT 1995 Contour 2.5 MTX 215K miles Son's car(dead and buried) 1997 Contour 2.0 ATX 1998 Contour 2.5 ATX 2004 Tauras Wagon 3.0 Duratec
#1370464 08/31/05 06:23 PM
I agree. Knuckle suspension blows major tailpipes to work on, but seems to be the most secure method for the strut to sit.
XL
#1370465 08/31/05 06:54 PM
It goes on a rachet, and the screw driver looking part goes in and splits the knuckle open enough free the strut from the knuckle.
The problem I've found with the tool, is that the tab on the struts themselves generally run the lenght and the slist on the knuckle, making it really hard to fit the spreader in to work properly/effectively.
Slow Vehicles in Training 01' Lightning 99' SVTC
#1370466 09/01/05 12:47 PM
Just use a mallet and knock it off the strut.
For the LOWER BALL JOINT I hammer in a chisel into the split to open it up. Oh and I go to town with PB Blaster on ANYTHIG that is a fastener or a contact zone between two parts that need to be separated.
#1370467 09/07/05 05:15 PM
True. I used a whole can doing my springs/struts, but didn't have one stuck bolt. Let it soak, and bang with a rubber mallet + 2x4. Mine just slid off, and it had 83k miles on it. Much easier than I expected.
Scott
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
#1370468 09/07/05 06:38 PM
F
F
I have a set of Koni's with the spring perches machined off ... all you would need then is some Ground Controls and you would be set ... $575 shipped is a steal! They are brand new, never used, and I already did the hard part and machined off the perches (no hack saw job here). PM if interested.
Page 2 of 2 1 2
