#1370343 08/26/05 02:02 AM
Ok so I finally get my ECU scanned and find that I'm getting P0172 Bank 1 running to rich, then as I go furhter into it the scanner is saying that 3 02senors aren't getting any readings whatsoever, btu I thought we only had two in the car. The symptoms thet I'm getting with the car is as soon as I put the car under load(hit the gas) I get no response at all I literally had the pedal to the floor and the engine didn't rev at all it just shut down. My dad had thought that I had a compression issue at first but I really don't know what it could be, the car is at a shop right now and they are trying to figure out what the problem is. The guy said when he did some testing he found my 02 senors seemed to be workign but somethign is sending a mixed signal to them.
Any help would be appreciated my car has been sitting for almost 6weeks now .
Aaron
#1370344 08/26/05 03:59 AM
If it really is running that rich you would smell it at the exhaust. Causes would be fuel pressure or MAF.
Actually it sounds like your cats are clogged or you are running way too lean, check fuel pressure response to engine load.
#1370345 08/26/05 09:28 PM
SVTs have Four O2 sensors. Bank 1 Upper, Bank 1 Lower, Bank 2 Upper, Bank 2 Lower. Check if the connectors are dirty or came out. And check if wiring are frayed.
#1370346 08/26/05 10:35 PM
I called the shop today this is what I heard
1)Let car idle and heard knocking then squeeling and then the car shut down it was only at 500rpm
2)Motor is now seized
3)No oil pressure(wasreading 0 PSI)
4)Oil was gooey and dark black
My motor is now shot, guess my car will be sitting until next sring
Aaron
