Posts: 35 |
Here is the problem. I bought my 99 SVT awhile ago, and bought it from a kid who put a keyless push start ignition on it, and when doing so he removed the ignition lock. My question is this..is a ignition lock easy to install. I have seen the locks for 60 bucks, and was wondering if there are any special tools needed for the install. Seems like it would be simple install, but was wondering if anyone has done this install before. Thanks
98 Contour SVT:
MUSTANG: 87 GT 5.0: TFS Twisted Wedge heads, TFS 1.6 Roller Rockers, Cobra 5.0 Intake, 3.73 gears, 76mm C&L MAF, JBA Headers, Moroso CAI, Steeda Tri-Ax Shifter
Posts: 5,345 |
Originally posted by fiveoh: My question is this..is a ignition lock easy to install.
Check out Autozone website for ignition switch and lock install.
Switch
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/d6/28/0900823d801bd628.jsp
Lock
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/d6/3c/0900823d801bd63c.jsp
And from Ford CD
Ignition Switch
Removal and Installation
Note:
It is not necessary to remove the steering wheel to remove the ignition switch.
1. Disconnect the battery ground cable.
2. Remove the two upper steering column shroud screws and remove steering column shroud.
3. Remove the lower steering column shroud retaining screws and remove steering column shroud.
4. Disconnect the ignition switch electrical connector.
5. Depress the locking tabs and remove the ignition switch.
Ignition Switch Lock Cylinder
Lock Cylinder Functional
Removal
Note:
The following procedure applies to vehicles that have a functional ignition lock cylinder. Lock cylinder keys are available for these vehicles, or the lock cylinder key numbers are known and the proper key can be made. Place ignition key in lock cylinder.
1. Disconnect battery ground cable.
2. Remove steering column shrouds.
3. Turn ignition lock cylinder to the accessory position.
4. Place a 3.17 mm (0.125 inch) diameter wire pin or small drift punch in hole at top of lock cylinder housing.
5. Press ignition lock cylinder retaining pin while pulling ignition lock cylinder from lock cylinder housing.
Installation
1. Install new ignition lock cylinder by turning it to accessory position and pressing retaining pin in.
2. Insert ignition lock cylinder into lock cylinder housing.
3. Turn ignition lock cylinder to the OFF position. This will permit ignition switch lock cylinder retaining pin to extend into the hole in the lock cylinder housing.
4. Rotate the ignition lock cylinder, using lock cylinder key, to ensure correct mechanical operation.
5. Install steering column shrouds as outlined.
6. Connect battery ground cable.
Lock Cylinder Non-Functional
Removal
Note:
The following procedure applies to vehicles in which the ignition switch lock cylinder is inoperative and the ignition switch lock cylinder cannot be rotated due to a lost or broken lock cylinder key, unknown key number, or an ignition switch lock cylinder cap that has been damaged and/or broken to the extent that the key cannot be rotated.
2. Remove steering column shrouds as outlined.
3. Note: Be careful when drilling: Do not damage lock cylinder housing.
Using a 3.17 mm (0.125 inch) drill, drill out ignition switch lock cylinder retaining pin.
4. Using a 15 mm (1/2 inch) drill, drill out ignition switch lock cylinder center.
5. Pull ignition lock cylinder from steering column tube.
6. Closely inspect lock cylinder housing for damage. If damage is apparent, the steering column tube must be replaced.
Installation
1. Replace steering column tube, if damaged.
2. Thoroughly clean all drill shavings and other foreign materials from steering column housing.
3. Install new ignition lock cylinder by turning it to accessory position and pressing retaining pin in.
4. Insert ignition lock cylinder into lock cylinder housing.
5. Turn ignition lock cylinder to the OFF position. This will permit ignition switch lock cylinder retaining pin to extend into the hole in the lock cylinder housing.
6. Rotate the ignition lock cylinder, using lock cylinder key, to ensure correct mechanical operation.
7. Install steering column shrouds as outlined.
8. Connect battery ground cable.
1996 V6 ATX 96K miles
Posts: 35 |
Thanks Tony! I think that I just need to install the lock, and not the ignition switch. From the directions it doesn't get much easier. Thanks, and I will let you know how it goes.
98 Contour SVT:
