Posts: 21,653 |
Don't some of the newer zetecs have the IAT and the MAF built together? You may not need to make a hole for the IAT sensor.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 11 |
I did a quick search and it says that the IAT may be built into the MAF. If you have 6 wires going into the MAF then the IAt is built in but if it has 4 wires going to it then it is seperate. I'm going to check that in the morning, cause I don't think there is a wire connected to the accordian tubing, thats was what was confusing me.
99 Contour SE
Posts: 1,118 |
well my IAT sensor was a seperate unit. i drilled a whole in the bottom of the 45 degree elbo and sealed up the sensor.
kevin m
98 T-red mystique gs
zetec ATX
| my ride |
Posts: 11 |
I went out and looked and it is seperate from the MAF. I finally understand everything now. Thanks everyone for all your help! This place is the best. Now to go and buy all the parts to put it together...
99 Contour SE
Posts: 27 |
Whats the difference in performance ratings between this and a cold air intake? Or is it the same? Yes i am a noobie at this.
1999 Contour SE, Zetec 4cly. CAI with stock air box, velocity stacks on CAI, optimized HP exhaust headers.
Goal: HP somewhere around 175-225. Stock look. Nice interior.
Posts: 11 |
Well I hooked everything up started the car and what surprise do I get....a check engine light! What could possibly went wrong I mean I didn't touch anything that wasn't supposed to be touched. Could it be that the IAT sensor got messed up with me taking it out and putting it in?
Well I then put the stock intake back on and the CEL is still on, so I'm clueless of to what happened. I followed the How-to step by step.
Is there any place that checks the codes for cheap?
99 Contour SE
Posts: 536 |
autozone and advanced both check them for free. get it scanned and post the code(s). my guess is that you left something unplugged.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 27 |
Whats the purpose of the velocity stacks? Which ones did you use?
Posts: 27 |
I have a seperate IAT on a 99 contour, anyone heard of it?
Posts: 2,483 |
The velocity stacks help to funnel air more effeciently. They are not really a necessity on the intake, so you can skip them.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
