Posts: 4,270 |
here are my slips (no order):
Reaction (based on the .000 being perfect) 60 ft 330ft 1/8 et 1/8 mph 1000 ft 1/4 et 1/4 mph
First
.331 2.5290 7.0919 10.8399 64.48 13.9830 16.6609 83.95
Second
.2890 2.5319 7.0399 10.7569 65.61 13.9190 16.6411 82.40
Third
.5220 2.4828 6.9969 10.7341 64.54 13.8710 16.5460 84.12
Fourth
.2177 2.4970 7.0693 10.8223 64.56 13.9881 16.6931 82.44
5th
.3641 2.4778 6.9679 10.6927 64.74 13.8259 16.4579 84.28
6th
.1439 2.5270 7.0041 10.6979 65.32 13.8112 16.4870 83.47
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 869 |
Alex, what mods do you have?
Posts: 5,810 |
Your 60' are all too high. If you launch at a slightly higher rpm, slip the clutch and don't worry about wheelspin then those will drop. I'd guess some energy suspension motormount inserts would help the wheel hop enough and that would improve the traction to the ground as well. Just technique should bring you down into the 2.3x range with what you got and that would be enough to get you into the mid 15's I'd guess. After that you'll need to start modding a little bit to get it on down to the low 15's.
See My Mods
Posts: 1,194 |
Originally posted by LoganB: Alex, what mods do you have?
Yea and what are the conditions at the track such as altitude, temp, humnidity? IIRC, last time I ran the 1/8th I ran a around a 10 flat with just an exhaust. I think I can do better at another track because Dallas goes up 6 feet during the course of the track.
Posts: 6,106 |
Wow, 2.5 60's? ![](/ubbthreads/images/graemlins/help.gif) 2800rpm launches with slipping the clutch to keep the rpms between 2800-3200 will net you some nice 2.2 60' times. Take .3 off your 60' and that's ~.6 off the 1/4. ![](/ubbthreads/images/graemlins/cool.gif) Mark
2000 Black CSVT
Posts: 4,270 |
Only mods are intake and exhaust, i had no wheel hop, and i was launching between 3000-3500, this track isn't the best by any means though.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
1989 Mustang LX 5.0
Posts: 1,859 |
Originally posted by MapOfTaziFoSho: What track?! Milan!? I have yet to see a 2.5 NA SVT hit 15's at that track.
Scott ran a 13.9 there tho! ![](/ubbthreads/images/graemlins/cool.gif)
BTW I ran 15.8 there with similar mods to you.
I ran a 15.3 there with some just some minor mods, i.e. removed rear mufflers and a generic old style superchip.
Alex what tires are you using? Maybe the issue. I know you had significantly lightened your stereo last time I saw you.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 5,810 |
Originally posted by SVT Driver627: Only mods are intake and exhaust, i had no wheel hop, and i was launching between 3000-3500, this track isn't the best by any means though.
BUT, are you letting the rpm drop or bog a little too much as you let out the clutch? If you launch at 3000+ you should get wheelspin on any SVT with stock tires. I'd guess you start and the rpm is dropping down below 2000 when the clutch bites so that you are out of your power band and the car then lugs to get back up. You'll have to let out on the clutch a little less, maybe just a tad slower so that the revs stay above 2500 when the car just starts to move until you get a few mph. Its hard to explain because it is something you just feel by practice and see by example.
See My Mods
Posts: 9,196 |
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
