Posts: 326 |
Ok a topic thats been beaten to death.
In Bat's catalog they list and sell the 22FS, and refer to it as " the best choice for use in the Duratec V6 engines"
so whats the difference?
I'm slightly confused on this one.
Thanks for any immediate help
Part # listed on box is AGSF 22FSM
99 Cougar V6 Tourmaline Green: MTX, KKM, Borla Dual...
Posts: 21,197 |
Who cares? Autolite APP764 are the ones you should be running. Double plats and cheap.
The FSM is a fine wire plug. Ford changed the recommended Duratec plug # to the FSM. Don't know why since double plats should only be used.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,693 |
The 22 is one heat range colder. You are not likely to need a colder plug unless you have extensive modifications. Start with the 32 (or the Autolite APP764) and see how the engine likes it and move to a colder plug if there are indications that the plug tip is too hot.
I doubt that you will need the colder plug.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,788 |
Fine wires make the old requirement for PPs irrelevent.
Either will work fine and will give similar service life.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 326 |
Thanks for the replies..
either way, replacing the AP764's(I didn't know they were in there)
My car loves me again.
Posts: 1,786 |
Originally posted by projectSHO89: Fine wires make the old requirement for PPs irrelevent.
Steve
You are kidding, right? Double-plats are needed due to the way the coilpack works. It has nothing to do with the wires.
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 1,788 |
Originally posted by Spork-O-Matic: Originally posted by projectSHO89: Fine wires make the old requirement for PPs irrelevent.
Steve
No, I am not kidding. Your information is out of date.
Steve
94 SHO ATX - 190K
Posts: 1,786 |
Originally posted by projectSHO89: Originally posted by Spork-O-Matic: Originally posted by projectSHO89: Fine wires make the old requirement for PPs irrelevent.
Steve
Steve
Do you have any idea HOW the Contour's coil pack works???? Spark goes one direction on one bank, then the other direction on the other bank.
This means that platinum is needed on the electrode on one bank, and then platinum is needed on the ground on the other bank.
From the factory, one bank has the -E plugs, and the other ones are -G plugs.
What the hell would wires have to do with the way the coilpack fires????
Greg, Todd, Tom, feel free to jump in here anytime.
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
SuperChipFOR SALE
Posts: 9,602 |
Fine wire plugs are the new standard in Ford waste fire systems. (for that matter many companies are using them now)
Why is that?
Because the amount of current required to start the spark jumping is exponentially less with a fine wire plug there is not the dramatic transfer of material every time.
Also the platinum used in the fine wire plugs is significantly better quality.
You will get "roughly" the same mileage out of a "properly" designed fine wire plug as a double platinum plug. 40-60k tops.
Fine wire plugs have better throttle response and promote less emissions. (stronger, more efficient spark kernel)
To respond to the original question...
Why are you running a step colder plug?
You are loosing mpg and even a little performance doing this on any car but a high compression hybrid with a wicked timing curve that is also running race fuel. (that or boost)
I found no benefit to running 1 step colder plugs on my 10.3 CR SVT with ignition timing near double the stock curves. I did lose mpg from running them. (i.e. they were too cold for optimum non-WOT fuel burn)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,356 |
What about something like the Autolite XP plugs?? Anyone try them yet?? I just did plugs like 15k (Autolite APP764) ago so i'm good for a while, but i'd be willing to give them a shot to see if it makes a difference in performance/gas mileage.
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
