Page 4 of 9 1 2 3 4 5 6 7 8 9
Here is what is done as of aug 25th!
Still need seal everything up, Aim the low beams, and make a cover plate.
Most of the hard work is done!!! it feels good.
Finising up the backing plates:
Finished HID Harness
Old HID ballasts (OMG WTF, so big) Vs. new ballast! so sexy, Ignitors sit on the back of the bulbs. (yes there is enough room!):
The only modification to the car I had to make (alot easier than milan made it out to be....)
Drum roll!
Quasi finished!:
That being said, im taking a break from these for the weekend. A couple more parts I need should be in sometime next week, and ill be able to start sealing things up.
Later,
Alex
Looking sweet man...
www.ChicagoCEG.com 2006 White Grand Prix
awowesome!
Oo (xxx)oO o xxxxxxxx o
Q
Q
#3162 of 6535 98 SVT Silver frost Viper Responder 791 w/ 2way remote start Let the modding begin!
what HID setup you using just outa curiousity?
Its a Hella Gen 4 HID set up with some used bulbs that came with the projectors. Ill be upgrading those to a 4000-6000k bulb, not sure yet.
I know this may be something of a frankenstein set up, but through ebay ive come out ALOT cheaper than the 'basic' tried and true system (90mm projectors x 4 + HID retro fit for H9's or H7's).
I just want CEG to know that it is possible to use a cheaper set up if you look around, and take the time to put in the effort to make it all work.
Ill say ive got more than 30 hours into it so far, and have wanted to give up quiet a few times. It takes some dedication
9
w3rd
I would stay under 6000K, it would be a crisp blue color under projectors, 4000K however would be amazing, it'll be very very bright...Also if you need help finding HID's stuff like wiring harness's, balasts and bulbs, shoot me a PM, I got a lot of sources...good luck meng!
Just thought I'd share for those of you that really want to go all out....
Sexy HID Projectors With Halos
THAT IS AWESOME WORK! Congratulations on a job well done!
I would like to see more close-ups of the housing and the fronts through the lens!
Congrats again on a job well done!
dion 98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
