Page 2 of 2 1 2
Update (since I have my computer back in order)
The Punch 500a2 makes it sounds pretty good.
"Woofer Cooker" .....
I can't wait for the Kicker amp to get here
1999 SE White AVH-P6500DVD Infinity Reference 6500CS Pioneer 5x7s Punch 360a2 Punch 500a2 Adire Tempest in a custom sealed 3.4cuft box Modded Xbox Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
Originally posted by KnuKonceptz:
The old underpowered woofer theory pops it ugly head....keep the signal clean and you should be fine with most any output level. The 38hz tuning is a bit on the high side. probably will have some good SPL but some loss at the low end due to the higher tuning frequency, will also keep the driver excursion down (hence no really low notes) Probably why Kicker recommends it, keep the coil in the gap.
Word. I would have suggested something like 30-32 hertz for a little bit better response at the penalty of little loss in SPL. But it would still get damn loud and would sound a lot better. Just my two cents here....
Morgan
1998 Contour GL 2.0L Zetec Stock as hell for the moment....
Morgan
I was just going with what Kicker suggested since it was my first ported box. I know if you are off with calculations more than a little bit, the woofer can get damaged
I feel Guilty, Oh so guilty
Honestly, the extra couple of hertz on the low end will be as noticeable as the change in output, which will be slight at best. I'd just leave it where it is for now, and if you ever wanted to play, you can extend the port outside of the box.
"If you are flammable and have legs, you are never blocking a fire exit" -Mitch Hedberg
really it would only change the tuning frequency and sound of the sub... but hey, kicker does a decent job. They don't know how to suggest a box for the Solo X though, they recommend (IIRC), 12.0 ported for SPL, and every one that I have seen has been bigger than that......
Morgan
MFG recommendations will always be on the low end of where optimal enclosures will be. It provides mechanical protection of drivers.
true, but wouldn't you think that on a pure SPL sub that has no real warranty that you would want them to have the optimal box off the bat? I would..... just me though....
Morgan
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
