The contour actually has a tach signal wire that is run to the back of the gauge cluster. I forget which one it is(it is in the pinout), but I am sure there is someone on here that knows. I believe on the printed circut board on mine it was labeled. If you go the other way you are going to have to get a MSD tach adaptor.
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
