#136589 09/22/01 10:17 PM
X
X
has anyone have these and have you encountered any problems with them?
Da Stealth Moblile
#136590 09/23/01 01:50 PM
I installed mine w/ a MonsterFlow filter a couple of weeks ago. I love the growl it gives at WOT. I've been careful driving in the rain and avoiding huge puddles b/c I don't want to hydrolock my engine....maybe get one of those AEM bypass valves to help out even more?? Also, the IAT sensor doesn't fit real well, so some wire ties might be necessary, and I've heard wrapping the SCA pipe in duct insulation will help keep the cold air cold.
Kevin
99 Contour SE Sport MTX V6
Mods: umm..some
#136591 09/24/01 01:31 PM
Love it, just installing it can be a bit of a pain
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
#136592 09/27/01 06:43 PM
Wouldnt it be hard to keep that thing clean? You guys like it better than the KKM and the SP Motorsports polished aluminum intake pipe?
99 SE
Mods in planning.
Audio:
Pioneer DEH-3000 CD player
Mephis coaxles replacing all factory Speakers
2 Orion XTR Pros 15"
2 Orion Xtreme 900s 900w to each 15
1 Orion Xtreme 500.4 powering the Coaxles
#136593 09/27/01 09:06 PM
I have a Cutom Injen Technology CAI, ceramic coated by Jet Hot Coatings. Things runs and feels great. Those of you with the CAI know how hot the pipe can get, and Jet Hot can cool it down (estimated) 30%. I noticed a huge difference in coating the pipe, and would recommend using something to cool it down even Thermo Wraps, etc.
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#136594 09/27/01 09:20 PM
I
I
I Have had mine installed for about a month. Originally I had an issue with my engine light coming on. I tried something SCA reccomended and it helped for a while but ended up wrapping my pipe in a tin insulation tape that was about 2" wide in an attemp to match temps between Mass air sensor and that other sensor ( Temp ? ) in the intake. I have only had one incident since then. Love the melodious sucking sound !!
99 Se,MTX,TS.
Formerly Dieter88, TbnPlr
NEW ding guards !!
#136595 09/28/01 03:54 AM
Had one, didn't like it that much. IMO it didn't add that much to performance. It also stalled the engine if I went from mid/high-RPMs to idle quickly, like when I coast from a highway off-ramp to a stoplight. Tried rotating the MAF to no avail.
There was this whistle below 3k RPMs. Might have been cool if it whistled above 3k RPMs, as you could pass it off as a turbo (heh), but not the other way around.
-Louis
1998 Black E0 #3826, lightly modded
