Posts: 7,100 |
We can't get ford to honor repair recalls on a "you HAVE to do it" basis, much less on a "you SHOULD do it!!" basis.
Ray
'99 CSVT - Silver #222/276
Posts: 1,317 |
okay i was just trying to bring up a point. i did not mean to anger anyone. Like i said before, i dont, and would never use anything less than 93 in my car.
~Ryan
1999 T-Red SVT Contour
41k Miles #1701 / 2760
B&M, Custom Y-Pipe, Alpine HU, Pioneer 6x8's & 6x9's
Posts: 217 |
I think this should be stickied with the current gas crunch...
Posts: 3,045 |
Originally posted by Ray:
("knock sensor will catch it" is a false statemnt, too, so don't go there.. the knock sensor operates BY DETECTING KNOCK... it has to HAVE HAPPENED, before it can do anything... once the sensor sees it, its too late...)
i can't tell you how many times i have had this conversation with mom. being a mom she is concerned about me. so she calls me every time some guy tells her i am wasting money on premium and explains (again) how i am wrong. i explain (again) what ray said. i have tried every method of explaining it to her short of sitting her down and giving her a full physics lesson.
bottom line:
can you technically use lower octane fuel in your csvt? yes should you use lower octane in your csvt? no
engine knock engine knock engine knock, by stanford with pictures
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 319 |
I don't see the point in buying an SVT model, spending the extra $$$ over a reg v6 for a more powerful car, only to try and save money by putting reg gas in it. At the very least, you will have reduced performance and fuel economy because the high compression SVT engine is engineered for higher octane fuel. You may as well buy a, cheaper non SVT tour that will be happy with 87 octane, but will give you less performance.
Posts: 10,015 |
Originally posted by dutchie: I don't see the point in buying an SVT model, spending the extra $$$ over a reg v6 for a more powerful car, only to try and save money by putting reg gas in it. At the very least, you will have reduced performance and fuel economy because the high compression SVT engine is engineered for higher octane fuel. You may as well buy a, cheaper non SVT tour that will be happy with 87 octane, but will give you less performance.
Eaxactly!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 3,045 |
agreed, and anyone who thinks otherwise can read the links and realize thinking otherwise is incorrect
Posts: 6,760 |
I have not run anything less than 91/93 in my CSVT. However, on a very similar platform (SHO) I have and do run 87 in it (typically though only in cold weather and on highway trips) and have had no issues. In theory, you could then do the same on a relatively stock CSVT.
Ryan
Trollin!
Posts: 6,106 |
Originally posted by RTStabler51: I have not run anything less than 91/93 in my CSVT. However, on a very similar platform (SHO) I have and do run 87 in it (typically though only in cold weather and on highway trips) and have had no issues. In theory, you could then do the same on a relatively stock CSVT.
All because you wanted a quarter pounder meal at McDonalds. Seriously, that's about all you can buy with the extra $3.00 you save yourself on a fillup.
Mark
2000 Black CSVT
Posts: 6,760 |
Actually, no, I did and do it because I can, simple as that. Originally posted by Y2KSVT: Originally posted by RTStabler51: I have not run anything less than 91/93 in my CSVT. However, on a very similar platform (SHO) I have and do run 87 in it (typically though only in cold weather and on highway trips) and have had no issues. In theory, you could then do the same on a relatively stock CSVT.
Mark
Ryan
Trollin!
