Posts: 566 |
My friend just purchased a 99 Se sport duratec 5 speed. We attempted to do the fog light mod on it, made a mistake and touched the orange w/black stripe aginst the solid black wire on the relay and now his headlights only come on if you push the turn signal stalk foreward (as if you were turning the high beams on). Its wierd because we blew a fuse when it happened and after that the only way to get the lights to work with the headlight switch was to jumper the solid orange wire with the orange and black wire together. Any Ideas?
99 Blk SE Sport
2.5 CD4E
Euro Focus SVT Wheels
5 % tint
Mesh Grilles w/indiglo ford
KKM intake filter
FMS 9mm wires
Superchip
Signal mirrors
Fog lamp mod
Dingless
A6 sidemarkers
Duals
SVT springs/struts
Posts: 3,335 |
Pushing the stalk forward? I could see pulling it back, using it in the flash mode.
Anyhow, you have checked fuse 26 in the passenger compartment, right?
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 566 |
Yes, we checked fuses, and I switched the fog lamp relay with the one from my car and still nothing.
99 Blk SE Sport
2.5 CD4E
5 % tint
KKM intake filter
FMS 9mm wires
Superchip
Signal mirrors
Fog lamp mod
Dingless
A6 sidemarkers
Duals
SVT springs/struts
Posts: 1,159 |
check all fuses both passenger and engine. and have you put the relay back the way it was and tried the lights then?
05 Chevy Colorado z71 4x4 *for sale*
97 Honda Accord 4door track whore *12.9 N/A* (blown and wrecked)
97 Honda Accord 4 door
03 Eclipse GS
Posts: 566 |
Yep I wired everything back like it was and still no healights unless you push the turn signal stalk foreward... I'm lost
99 Blk SE Sport
2.5 CD4E
5 % tint
KKM intake filter
FMS 9mm wires
Superchip
Signal mirrors
Fog lamp mod
Dingless
A6 sidemarkers
Duals
SVT springs/struts
Posts: 9,442 |
Does he have daytime running lights by chance?
Posts: 1,159 |
sounds like it would have to be a fuse or a relay thats blown
03 Eclipse GS
Posts: 566 |
He doesn't have daytime running lights. We changed the relay under the hood with the one from my car also and nothing changed. Is there a relay that relates to that under the dash?
99 Blk SE Sport
2.5 CD4E
5 % tint
KKM intake filter
FMS 9mm wires
Superchip
Signal mirrors
Fog lamp mod
Dingless
A6 sidemarkers
Duals
SVT springs/struts
Posts: 3,816 |
Maybe it fried the headlight switch or a wire going to/from there... maybe throw your headlight switch in and see if it works.
Posts: 432 |
Originally posted by MCconnection cc: He doesn't have daytime running lights. We changed the relay under the hood with the one from my car also and nothing changed. Is there a relay that relates to that under the dash?
If he doesn't have daytime running lights...then what operates the headlights? Pushing it forward is for the high beams and pulling it towards you is flash to pass. I dont know your car..has it got a switch for regular headlights?? If not then it has daytime running headlights, and the DRL relay could be gone. Also check for one low beam headlight element burnt out...that also could be the problem.
