What LIM are you using right now? Did you use the 3L heads or your old 2.5L heads? If you used the 3L heads, were they oval ports with the plastic UIM and LIM?
Lots of info needed before an answer can be given!!
PS you REALLLY should run the 24lb Injectors that come on the 3L to make it run right. 19's are too small for a 3L - they are meant for SVT's.
