Posts: 34 |
Has anyone ever had trans fluid spray out the front seal, on to the clutch and spill onto the ground? Right after You just put sycro's and a torsen in.
My question is will i have to replace the clutch, its a spec II
IN 3rd gear at 3500 if i stand on it the clutch slips. But it doesnt do it in first
Posts: 4,693 |
The clutch is probably slipping because it is oil soaked. Vey likely it can be cleaned with brake clean. You need to clean up the bell housing and pressure plate anyway.
As much labor as there is to get to the clutch, if in doubt, replace it. Clean it up and then try and make a determination. If there is even a shodow of doubt, replace it unless you don't mind going back in if it still slips.
I have suceeded in cleaning oil soaked clutches, but there were much easier to get to.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 10,015 |
Hmm, did you replace the input shaft seal/slave cylinder when you had it apart, and if so what did you use - a ACTUAL Ford slave or a knock-off?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 9,602 |
Originally posted by Stazi: Hmm, did you replace the input shaft seal/slave cylinder when you had it apart, and if so what did you use - a ACTUAL Ford slave or a knock-off?
I agree. Sounds like the slave-T/O 0-ring/seal is leaking.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,572 |
Man that sucks , hope I don't have any issues when I do mine .
Check me out for awsome powder coating deals
www.powdercoatingworld.com
People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
Posts: 34 |
The throwout bearing came with the spec stage 2 kit. So hopefully i only need a trans seal
Posts: 110 |
Originally posted by CSVT98driver: The throwout bearing came with the spec stage 2 kit. So hopefully i only need a trans seal
You need a FORD T/O bearing. Aftermarket ones are just knock offs.
Posts: 4,970 |
Wow, the worst thing that could happen for a kevlar clutch. I'd kiss it goodbye, I doubt it can be saved. I would bet my left nut that it will only glaze over now
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
