Gloves Offline OP
I am about to install my 1st system and my friend said I would need a capacitator because my stock alternator is probably weak. Is this true?
I am running 700 Watts RMS... Will I have problems with lights dimming? will there be a huge drain on my battery? or will I need to buy a high output alt?
I do not really want to buy either one... but I do not have my system installed yet so I do not even know the problems I may have. How powerful is a stock contour alt? I heard it was 130 amp alternator... is that correct? Will that be able to handle me putting out 700 watts without any problems in my cars electrical system? Will I need to upgrade wires?
lol, so many questions. I am just confused. Will I have any of these problems? Any help is appreciated.
I feel Guilty, Oh so guilty
Get your alternator tested at your local autozone. If its putting out significantly less output than it is rated for (130A) then replace it, potentially with somehting larger. That being said, 700w shouldn't even come close to taxing the stock electrical system.
"If you are flammable and have legs, you are never blocking a fire exit" -Mitch Hedberg
Gloves Offline OP
thanks. Do you think I would even need a cap? That is what my friend recommended. Also, how much does it cost to have the alt tested?
Having the alternator tested should be free .
Check me out for awsome powder coating deals www.powdercoatingworld.com People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
Captain Impound Boy
Captain Impound Boy
Caps are highly overrated!!!!!
Get a yellow top way before you get a cap, They install the say way and a yellow top is only slightly more expensive.
But as dave said you shouldn't need either, Upgrade the Big 3 and you should be all set
And I would recommend an Oddysey battery over any Optima. Might be a few more dollars, but well worth the investment.
Why?
My yellow top has been perfectly fine, and I have put it through hours of engine off listening sessions since 2001 without a single problem. It also starts my car easily in the dead of winter too.
Bob Johann SoundQ SVT 1998 T-Red SVT Contour #3088 2001 IASCA Pro Street 1-600 Champion 2002 SLAP Pro Street 1-600 Champion 2002 MECA SQL Master Class Champion 2003 IASCA StreetX 1-600 Champion 2005 SLAP Expert Street Champion
Captain Impound Boy
Captain Impound Boy
Dave lives in a fantasy world where no name products out preform everything else...
I have a Red top now and its flat out amazing.. a yellow top will soon be added
waht are the big 3???
pardon my lack of knowledge here.
Anybody ever upgraded the power cable from the battery to the alternator/starter, i.e. using a larger gauge wire and slightly larger mega fuse. If so any significant results? I may do this soon.
'99 Silver svt For sale 19" Axis Neo wheels 3.0 parts, pre-98 trunk, Check classifieds bp.powell@comcast.net
Moderated by  dnewma04_dup1
