is there any?? and has anybody even tried cuting them to make them shorter all i could do is drill the hole in my shift knob so it had a lower profile without affecting the whole pulling into reverse action...
no
yes
no
search as this was just covered again
cut it and be happy if you like but it will not be a true short shifter
doesnt matter shorter is better than stock shifter
W
W
Originally posted by brapple:
... but it will not be a true short shifter
Not true.
It is a shifter, it is truly shorter than stock, therefore it is a 'true short shifter'
The throw on upper lever arm will be shorter since the arm is shorter.
I have the steeda triax and it is very nice with nice hardware. It actually has a changed ratio on the shifter but it isn't as short as the B&M, which has a very sort length but the same arm length as stock below the pivot.
Not true.
i thought the longer length of the steeda below the piviot point is what made it a true short shifter, yes the B&M is shorter but since the length below the piviot poit is shorter it is just a shortened shifter
W
W
Well, it is just symantics I guess.
The steed changes the ratio of motion versus the stock shifter and keeps the length relatively the same. This means that the shift knob isn't lower than the B&M and hardly lower than stock.
The ratio of motion has been changed to help shorten the throw distance even though the upper portion above the pivot isn't as short as the B&M
The B&M has a shorter upper arm than stock but approximately the same length lower arm below the pivot. The upper arm being shorter means that the throw is also shorter. Here is a graphical depiction (Sort of)
stock:
--------o-->
B&M
-----o-->
Steeda
------o--->
If you look at the pictures the shifters are pictured on their sides with the circle as the pivot point and the > symbol as where the cable hooks up.
The dashes are the shaft and the number of them corresponds to the length.
Stock is the longest shaft above the pivot.
The B&M shortens the shaft but keeps the shaft below the pivot the same lenth.
The Steeda shortens the upper shaft and lengthens the lower shaft. You have to measure the length of the upper to lower shafts to compare the ratio and see which truly has the shorter throw.
So you see, a shorter throw shift need only trace out a distance that the shift knob moves shorter than stock to be considered a shorter throw, irregardless of the length of the shafts. That is why if all else is equal, cutting the upper shaft of the stock shifter will shorten the throw automatically.
You must remember that the effort required to make the shift will also change. The shorter the shifter throw the less leverage advantage it has the the more stiff it will feel trying to shift.
W
W
Just to add more of an example, the ratio for the Steeda TriAx is:
2.31:1 inch ratio
This comes from a 9.25" upper shaft length over a 4" lower shaft length measured from tip to center of the ball pivots.
and the B&M is:
2.36:1 inch ratio
calculated from a 8.25" upper shaft over a 3.5" lower shaft.
This is so close to the same that it hardly seems worth it to distinguish between the two in terms of a "shorter throw".
The visual difference is that the shift knob with the B&M sits much closer to the console or "lower" than the Steeda, which sits almost as high as stock.
In truth, the B&M with almost an identical throw to the Steeda but sitting much lower gives a more "sport car" look than the steeda.
On the other hand if you want a shorter throw but you're a tall person and want the shifter closer to the stock height, then the Steeda is the right shifter for you.
Back to the original question:
Will a cut stock shifter give you a shorter throw? YES!
You can very well make it the same or shorter throw and height than the B&M.
If you guys want I can go outside tomorrow and measure the length of the stock shifter and post it's ratio.
Y
Y
stock:
--------o-->
B&M
-----o-->
Steeda
------o--->
Very nice rendition Tom! I like that But for those that need an actual visual. IMHO, the best option would be a Steeda shifter, cut down to B&M length!
Mark
this was hijacked haha
stock:
--------o-->
B&M
-----o-->
Steeda
------o--->
http://home.comcast.net/~elky1/shiftbeforesm.jpg
Mark
I see you already grabbed the image from Elky, but om him, he cut his Steeda to the B&M length, and with his 13 oz shift knob the thing is sick
