Page 2 of 2 1 2
John the tranny fluid was changed earlier this year and I put in Mobil 1 Synthetic. If it looks like it is just the FD I would consider changing out the fluid just as an experiment to see if anything changes.
BTW .... no autocrossing here.... pure open track events only. Nonetheless it will still heat up the tranny.
Fern
1999 SVT Contour Silver Frost Bassani,Ground Controls Street..17x7 Rage 5.0/Falken Azenis Sport 225/45/ZR17 Track...Kosei K-1 17x7.5 Avon Tech Ra 225/45/17/ Quaife/ SPEC Stage III/ Fidanza /Capaldi Racing 4.5 final drive/TCE Brake Kit 13"
I
I
Gear will whine if they donâ??t mesh perfectly. If a gear set is not cut as a set, it will make noise. Improper installation., too much or too little backlash or improper centre distance spacing can make gears â??singâ? a little too. Tooth design and cross sectional profile shape will also make gears whine. Herring bone cut gears are always loud, straight cut gears are loud too. Sometimes this is necessary to make a gear set strong. I think, in your case, this is either installation error or more likely manufacturer error of the gear set.
If this noise was there after install, you should have taken the car back to the shop and complained.
Also, sometimes damaged or worn out bearings can make noises like this too. If the bearings were damaged during the swap, the noise would make sense.
I hope this helps.
'98 Contour 2.5L, 5-Speed, 100% stock '85 Porsche 928 5-speed, Supercharged & Intercooled 12.87sec @ 109mph
Fern, I'd be interested in hearing this from the outside. I've heard it from the inside before, and my car exhibits gear rollever and pp rattle. I think it's just the nature of running an alu flywheel and a HD PP.
Then: 99 Silver Frost SVT #1919 237hp/219tq All Motor Now: 06 White STI Parts 4 sale
Ah... sorry Fern. For some reason I thought you did autocrossing.
96 LX 3.0L MTX - Black/Tan K&N; 12lb F/W & uprated clutch 2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod; UN-tuned Mod; 3rd Gear Synro-Crunch Mod 280K on the Shell, and 40ish on the Motor... 1/4 mile?? Yeah, it's a fun daily driver...
Thx everyone... I will be offering up rides in the car with a few people over the next little while to see what people think the noise could be. If anyone local is interested in hearing what this sounds like send me a PM and we can hook up over the weekend. I just want to get as many opinions as I can before I start tearing things out looking for a problem that may or may not exist.
Thx guys
Fern
I'm not a mechanic, but I will take a ride in your car tho
Aaron
Page 2 of 2 1 2
Moderated by  Gerald_dup1, mbb41_dup1
