Hey,
There is a rather noisy ticking sound coming from the rear cylinder bank. I'm almost positive it is a hydraulic lash adjuster. How difficult will this be to replace with the engine in the car? I know that in order to get to the lash adjusters, removal of the camshafts is necessary. If this engine had a timing belt, I would be able to index the position of the gear to the belt, then remove the gear from the belt and pull out the individual camshaft... but that isn't the case with a timing chain... or is it? Will I be able to unbolt the timing gear from the end of the camshaft and then slide the camshaft out, or do I have to pull the whole side of the engine off and then remove the timing chain?
Thanks guys/gals.
