Posts: 611 |
Quite possible. Do you have an ADC chip in your car. If you get a tune you should get more torque than hp. I still don't have a chip but I will eventually. Right now it is just tuned with my Apexi S-AFC.
The car I built for NateS ended up with 200tq and in the 190's for hp. I had a chip made for that car. It was a full oval port ported to svt intakes. All stock svt parts otherwise not even gutted cats or an intake.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 9,602 |
Originally posted by rkneeshaw3.0: I'm curious why some here have such low torque numbers. I put down 189hp/186tq at the wheels with stock pre-cats/stock SVT exhaust/bat-y/2.5L stock SVT heads and cams/SVT LIM+UIM+TB+K&N. If I open my exhuast up with headers or optimal cat-bak (or both) am I going to see a drop in torque and increase in HP?
Are you claiming before IMRC Torque numbers? (below 4000 rpm) Many people do not claim that because it's a false indication of the true powerband.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,570 |
Originally posted by DemonSVT: Originally posted by rkneeshaw3.0: I'm curious why some here have such low torque numbers. I put down 189hp/186tq at the wheels with stock pre-cats/stock SVT exhaust/bat-y/2.5L stock SVT heads and cams/SVT LIM+UIM+TB+K&N. If I open my exhuast up with headers or optimal cat-bak (or both) am I going to see a drop in torque and increase in HP?
This is what I'm claiming:
I love the torque and would hate to loose it by opening up the exhaust. I wish I understood the relationship between torque and HP better
Posts: 3,570 |
Originally posted by Blackcoog: Quite possible. Do you have an ADC chip in your car. If you get a tune you should get more torque than hp. I still don't have a chip but I will eventually. Right now it is just tuned with my Apexi S-AFC.
Yup, I have a ADC chip. That makes sense then. It seems oval port head installs have that extra 10-15 ft-lbs of torque than the SVT head installs. The HP is right on. My setup is basicly just that; a stock SVT except BAT y-pipe and 3L shortblock (minus fidanza and quaife in the driveline but I didn't think that counted here hehe).
Posts: 7,025 |
Originally posted by rkneeshaw3.0: Yup, I have a ADC chip. That makes sense then. It seems oval port head installs have that extra 10-15 ft-lbs of torque than the SVT head installs. The HP is right on. My setup is basicly just that; a stock SVT except BAT y-pipe and 3L shortblock (minus fidanza and quaife in the driveline but I didn't think that counted here hehe).
Marks 3.0L split port hybrid made 195 wtq.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 6,106 |
True dat!
Mark
2000 Black CSVT
Posts: 5,975 |
That's it, I know it's not realistic to compare dyno #s, but I need to get my 3L on a DynoJet.
Posts: 6,106 |
Originally posted by SVT PETE: That's it, I know it's not realistic to compare dyno #s, but I need to get my 3L on a DynoJet.
Was my post the straw that broke the camel's back? If so, then GOOD! Cause I've been wanting to see what kind of power your car makes on a Dynojet!
IIRC, you've got the SHM headers correct? What kind of headwork?
Mark
2000 Black CSVT
Posts: 5,975 |
Originally posted by Y2KSVT: Originally posted by SVT PETE: That's it, I know it's not realistic to compare dyno #s, but I need to get my 3L on a DynoJet.
It's the fact that 9+/10 dyno on DynoJets. I would loosely like to see where I stand.
3.0 hybrid by DanG
Ported & polished heads by kinger
SHM long tube headers, Jet Hot coated
Extrude Honed Power Flow UIM, Jet Hot coated
CTA intake pipe, Jet Hot coated
65mm throttle body, optimized
AFE 8" filter
Bassani cat-back exhaust
Edelbrock muffler (resonator)
Torsen LSD
SPEC Stage 1 clutch
SPEC flywheel
If I have money after paying for the wedding, hopefully a chip/tune.
As a comparison on a Mustang dyno:
scottd60 w/ intake Bassani
159.0hp, 127.6tq
Myself: 202.4hp, 177tq
Posts: 6,106 |
Originally posted by SVT PETE: 3.0 hybrid by DanG Ported & polished heads by kinger SHM long tube headers, Jet Hot coated Extrude Honed Power Flow UIM, Jet Hot coated CTA intake pipe, Jet Hot coated 65mm throttle body, optimized AFE 8" filter Bassani cat-back exhaust Edelbrock muffler (resonator) Torsen LSD SPEC Stage 1 clutch SPEC flywheel
202.4hp, 177tq
That is very bizarre to me to see such low torque #'s, especially with the long tubes! You've actually got a very similar setup to mine, as I'm running a hybrid with 65mm T/B, CTA pipe, 8" filter, Bassani catback w/ Magnaflow res. Only real difference is that you've got PnP heads, what appears to be a Max E/H UIM??, and long tubes as opposed to my shorties. I think you'll see a LOT of power once you get it tuned, and everything is dialed in. What injectors are you running right now? Stock MAF?
Mark
2000 Black CSVT
