Page 2 of 3 1 2 3
#1358215 08/13/05 07:03 AM
TjZ Offline
so the best one to get is the ZX Tuner one?
What year do you have?
99
I would say the zxtuner one.
http://www.zx2racing.com/store/closeup.asp?cid=33&pid=117&offset=0
That one?
I am working on building an exhaust system so those headers what other stuff do you recommend?
#1358216 08/13/05 07:43 AM
CEG road warrior
CEG road warrior
2.25" exhaust piping
2.25" High flow cat
Magnaflow muffler for resonator
Magnaflow muffler in back
This will give you the best sound w/o being obnoxiously loud. This will also give the best all around N/A performance.
#1358217 08/13/05 12:18 PM
R_G Offline
ZX2's or Cougar's?
#1358218 08/13/05 03:30 PM
CEG road warrior
CEG road warrior
ZX2's or Cougar's?
Really doesn't matter.
#1358219 08/16/05 09:28 AM
Originally posted by ButtonPuncher:
You would need to modify the downpipe to fit.
Pretty much any header/cat combo will have to be modified though, right?
Also, that particular header doesn't have the block to flange bracket. It is more prone to cracking than others.
Does this meanthat I should avoid it at all costs?
1996, will that change anything? Or is the zxtuner one still the best bet?
2000 Mystique LS Duratec 2.5L MTX
Pretty please, just a little insight...
CEG road warrior
CEG road warrior
For the 96 I would recommend a Focus header. It will have the spot for the EGR. Yes, every header will have to modified to fit.
Doesn't ZXtuner have a header that is supost to fit the Contour?
As recommended get a Focus header and keep your EGR.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
The ZXTuner Cougar header will only fit directly to a 98+ Contour. That's because the 98+ Contour has no EGR. If you wanted to use the ZXtuner Cougar header on a Pre-98, you would have to disable EGR. It's not a very difficult 15 minute job.
BTW, I'm a bit wary of the ZXtuner header. It has no flex pipe at all. It is solid from the header to the resonator flange. If I were going to buy one, I would have a stainless flex pipe added right before the flange that connects to the resonator. (In the stock location.) I haven't checked the Cougar forums. I wonder if there have been any reports of cracking?
HTH,
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
You can put a hole in the header to have EGR functional.
Page 2 of 3 1 2 3
Moderated by  Loco4G63
