Page 3 of 3 1 2 3
#135753 09/06/01 03:07 AM
Administrator
Administrator
Originally posted by Krafty:
I had trouble getting the rear ford emblem off, kinda chipped it so I stopped before I did more damage...how did you get it off Chris???
To get the rear emblem off I used a thin knife. However, I recommend the dental floss method for both of them.
-Using something very thin, push a loop of dental floss into the crack and behind the emblem.
-Go back and forth with it, and try sliding it to the side.
-For the front, remove the grille with the two screws up top, and the two tabs on the bottom. Use a screwdriver and put the tabs out.
-There are two 10mm nuts on the back of the grille that hold the emblem on. There are two parts to that emblem. The backing and the emblem.
That's how you get them off. Take care not to cut your hands with the floss. If the front isn't working, try putting it in boiling water to soften the adhesive.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#135754 09/06/01 04:22 AM
Thanks Chris...tried the dental floss method to no avail the last time. Maybe I just need to stick with it a little longer and hopefully I'll get it, I want painted emblems!!
Ryan
Latest Mod: Mirko Splitter
#135755 09/06/01 04:42 AM
By the way on the rear pry from the top because it has a tab in a slot at the bottom AND IT WILL NOT come out if you pry it from the bottom!
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
#135756 09/06/01 02:26 PM
Administrator
Administrator
Correct! The same applied for the front one. I forgot to mention that. Thanks, Howard.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#135757 09/06/01 04:28 PM
PAA Offline
I spent $11 for a new front emblem and used the old chrome piece and the new ford emblem. The back emblem is $16, I bought it anyway. I figured it would be easier than messing with the ones on the car. I figured I would crack one of the damn things anyway. They look good, I will put them on tonight on my white 98 SE.
What type of apoxy should I use? I want something that is garranted not to come off.
'98 SE Sport
Fog light mod and sidemarkers
No significant power mod
#135758 09/06/01 05:00 PM
Administrator
Administrator
Just wait until the Saturday night, and I will help you if you come to Keller's. Also, do you have dual exhaust?? I saw someone on NW-HWY about a month ago with a nice white SE with dual's. It sounded nice. Was that you?? Hope you can make it Saturday.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#135759 09/10/01 05:40 AM
I just did my rear!! WOHOO looks awesome! my front was chipped already so I took the darn thing of and I going to put a silver mesh there instead. If u are trying to get the rear logo off all u need is to things. 2 thin small screw drivers and a friend. Just push the screw driver all the way in on the right side and lift slowly. As soon as its lifting get your friend to put in a second one and slowly lift. Try to be careful and gentle and your set. Will post pics when got chance. LOOOKS SWEEEEET! Thanks Chris for the idea. Sorry about the long post. cool
98 Contour V6 MTX
KKM/Niehoff Wires/Bosh+4/Mobil 1 Oil/Tranny/Pioneer CD/Speakers
Predator Alarm...more 2 come!
"Dana, if by accident, I dropped an 7mm rachet inside your secondaries your engine would be ok? right?"
"Trust me if I could go back and change, I would be stuck in the past" MartinS
Page 3 of 3 1 2 3
