Originally posted by Krafty:
I had trouble getting the rear ford emblem off, kinda chipped it so I stopped before I did more damage...how did you get it off Chris???
To get the rear emblem off I used a thin knife. However, I recommend the dental floss method for both of them.
-Using something very thin, push a loop of dental floss into the crack and behind the emblem.
-Go back and forth with it, and try sliding it to the side.
-For the front, remove the grille with the two screws up top, and the two tabs on the bottom. Use a screwdriver and put the tabs out.
-There are two 10mm nuts on the back of the grille that hold the emblem on. There are two parts to that emblem. The backing and the emblem.
That's how you get them off. Take care not to cut your hands with the floss. If the front isn't working, try putting it in boiling water to soften the adhesive.
