Posts: 330 |
People should post pictures...What happens if you dont have a heat shield....
97 V6 ATX 20,000 Miles
alpine cda 9811
Alpine MRV-F357
hifonics brutus BX2000D
2 Kicker L7 15
I NEED GREY LEATHER DOOR PANELS!!!!!!
Flip out monitor
PS2
Spr-175a
SPR-69LP
SPR-57LS
60 Ft EDEAD
Posts: 584 |
Originally posted by contourdude: People should post pictures...What happens if you dont have a heat shield....
If you have an open air filter in the engine bay (no heatshield), then you intake will heatsoak and you will noticeably lose power.
E0 Silver Frost CSVT #3095/6535
Alpine CDA-9851
Posts: 36 |
by using a plastic garbage can did you use on peice and cut it to size or did you use many peices and put them together somehow? because i cant find a decent size plastic container to save my life
Posts: 1,746 |
Make one any-way you can...As long as it is completely sealed from any engine heat. (both sides, underneath, and before the MAF....hood creates another side, now the only place left thats open to draw air in is from the fender which will supply cooler air)
2000 Contour SVT
SF - #542 of 2150
Posts: 3,045 |
Originally posted by racerm515: by using a plastic garbage can did you use on peice and cut it to size or did you use many peices and put them together somehow? because i cant find a decent size plastic container to save my life
go to home depot.
example: i pulled this from a thread i found just now by searching in the pics and vids forum and typing "heatshield" in the search term.
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 857 |
I wonder, after you're done making this heatshield and sealing it around the filter.. is it really that much better than a stock SVT airbox?
I've gone through the KKM, K&N OEM drop-in, monsterflow foam filter (with and without the SCA CAI), the now-defunct SMA CAI, and now I'm back to the stock airbox again. Admittedly the KKM was without a heatshield, but really the only noticeable difference between any of these was sound level and a lighter wallet...
Posts: 36 |
does the heatsheild in that pic have a bottom to it? is a bottom necessary or is 3 sides and a top enough
Posts: 3,867 |
Originally posted by louisw: I wonder, after you're done making this heatshield and sealing it around the filter.. is it really that much better than a stock SVT airbox?
Dyno?
Function before fashion.
'96 Contour SE
Posts: 124 |
that is why just about anyone who knows anything has said that these will for the most part only give you a negligable gain in hp. any extra power noticed is most likely in your head, and the main advantage is simply the sound you get(and of course a re-usable filter)
98-98.5 Silver Contour SVT
short shifter
Panasonic HU
2 12" MTX 8000's
MA Audio mono block amp
homemade box
Posts: 3,867 |
Originally posted by esveetee: Originally posted by louisw: I wonder, after you're done making this heatshield and sealing it around the filter.. is it really that much better than a stock SVT airbox?
I have an open ITG filter on the car. I have an SVT airbox in the garage. Just need to find time to test and swap.
'96 Contour SE
