Posts: 1,367 |
Well problem solved. I took it to Capital Ford here in Raleigh and it took a few days longer (a whopping 2) but after all was said and done, it was indeed the starter. I asked them about wiring and electronics and they them first, but everything tested out ok so they replaced the starter. Total was about $320, $180 was for the starter and remainder being labor and testing (that I requested).
Actually it's less than I thought it would be and the car drove home just fine.
Next up is fuel pumped replacement and A/C fix, in that order.
But trackdays come first!!
Sal Khan
00 SVT - Not pretty
00 Aprilia RSV Mille - Also Loved.
http://www.thelunchjournals.com
"I just want someone I can stand once her mouth is free of obstruction."
Posts: 351 |
Starters don't cost $180, and it is barely a 1 hour job. Jeez, I think I'll open a shop.
Black 2000 SVT Contour w/ Prairie Tan
MSDS Headers | Magnaflow | Mirko Splitter | Fidanza Short Throw Shifter | Kenwood KVT-815 LCD/DVD
Posts: 5,345 |
Originally posted by Big_B: Starters don't cost $180, and it is barely a 1 hour job.
Brand new Ford starter would. And there were requests for other things to be tested too.
1996 V6 ATX 96K miles
Posts: 351 |
Originally posted by Tony2005: Originally posted by Big_B: Starters don't cost $180, and it is barely a 1 hour job.
That's right, he did go to the dealership, probably why labor was so high also.
Posts: 736 |
Originally posted by SalKhan: Well I checked the cables, they looked good.
Try putting vise grips on them relly tight and on the accessory connection that goes to the fuse box too, you might have a slightly loose connection that can cause that
99 ATX Contour 130k w/ a 21k tranny freshly installed
Secret Project in the works
Originally posted by unknown: Never argue with an idiot, ppl may not be able to tell the difference between you.
Posts: 736 |
Originally posted by Big_B: Starters don't cost $180, and it is barely a 1 hour job. Jeez, I think I'll open a shop.
A rebuilt alt from o'rilleys is $175 and shop time is 2.2 hours according to alldata and my shop charges $76 an hour
so with tax and everything it's right around 360 give or take 20 bucks or so so it's about on par for a ford dealership.
Posts: 301 |
ITs a starter not an alternator.
Originally posted by PÃ?â?¢WDÃ?â?°Ã?®CÃ?Ë?Ã?Æ?TMÃ?â?¬N: I can do anything if i can find that powder .
