#1355485 08/08/05 02:24 AM
ToTalXS Offline OP
ok i just purchased my car and found the entire trunk lid is layered in this stuff....it looks alot more like tar with aluminum foil backing...the original dynamat came out nicely but this stuff thats on the trunk lid looks messy to take off....anyone have any experience removing this stuff?...any suggestions would be appreciated....thanks smuch
-Shawn
2000 Contour SVT #1567
N
N
Why do yo uwant to remove it??
Just leave it there and cover it with some second skin stuff to make it look nice.
http://secondskinaudio.com/products/
1998 T-Red CSVT 3.0L
I agree. It isn't hurting anything. Unless you plan on turning your car into a "drag" car and start gutting it for weight...it really wont make a difference. And in the long run, if you decide you want some subwoofers, you wont have to buy some sound deadening material which can be pretty expensive. If you must remove it for whatever reason, there are tons of degreasers and tar removers on the market. Go check out your local Autozone and you'll find something. I promise it will be messy and you'll probably wind up scraping the stuff off (as well as scraping your trunk lid). Best of luck in whichever way you choose.
2000 Contour SVT SF - #542 of 2150
ToTalXS Offline OP
the reason i would like it removed is because it makes the trunk lid so heavy that when you pop the trunk sometimes it closes itself...i think i might wait until it turns colder and see about removing it then...
W
W
Just get the spring that people with spoilers get, it makes the lid pop when the trunk lid is released.
1999 Contour SE Duratec ATX My feet and the Stra�Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
spring were might i find this spring i would like a spring when ever i pop my trunk it just sits there tilll i open it my self
1996 zetec atx 19.3381 at 71.51 mph 1/4 mile click me for an interesting sitea wbsite you should check outjoined the 100k+ club 5/21/06
Yean where can you get this from? The dealer maybe?
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
i have one, works great for pappng the trunk out fo the latch, when i first got the car, the trunk kept tatching itself back shut before i could pull it open, all problems now solved.
Trunk will not pop open
This is a common problem.
Author: F111D F
Applicable to: All vehicles
Added: 02/25/2003
Updated: 02/25/2003
The part number for the spring popper for all contique trunks is F8RZ-63431B04-AA . This will assist the opening of the trunk lid to help it to pop the lid out of the latch which the struts will not do.
Moderated by  dnewma04_dup1
