Page 2 of 2 1 2
#1355242 08/12/05 12:21 AM
W
W
Originally posted by DemonSVT:
Originally posted by Ronan:
Originally posted by carzyjay:
should have went with the whole 3.0L.
There are lots of good reasons that people do hybrids, here are two;
(1) Cost
(2) Maintaining the 'stock' 2.5L look for insurance reasons....
It's not cheaper to do a hybrid.
Both engines look the same and use the same valve covers in the end.
Those are not good reasons.
Au contrare, it is effectively similar in cost and CAN be done cheaper or it can be more expensive.
#1355243 08/12/05 03:21 AM
That's worse then me...
So basically you are disagreeing that you agree with me in disagreement.
Swap for swap they are roughly the same cost.
However a hybrid costs more if you want 3L valves for your 3L engine though.
#1355244 08/12/05 10:51 PM
W
W
No. The valves add roughly $200 in headwork. That offsets the extensive porting and the added material requirements and labor that needs to be added to the ovalports just to get them to seal.
You have the peace of mind that all stock parts will work with the hybrid and all you really need is the 3L exhaust valves, not the intakes if you are trying to save money. Keeping the 32mm intakes will improve the torque anyway since they are very similar to the 3L 35mm valves in size and in fact use the same external diameter valve seats. I would guess that I could convert an engine over to a 3L hybrid for about $150 in machine shop work which would include tanking and checking for leaks if I just improved the exhaust valves.
Then I'd probably end up with a fatter torque curve with the smaller intakes (also verified by Dyno2000) with some decent porting.
Every thing else would cost the same as far as gaskets.
If I did just the basic swap it is much less work than an ovalport hybrid along with a tube of jb weld. Everything just bolts back up and it ends up the same or cheaper cost with less work.
So it really remains to be seen which is actually better.
BTW, there has been NO ovalport 3L conversion to actually best the 3L hybrids in total horsepower to the ground yet.
If you count DavidZ and even my own motor, no one has actually beat them yet with an ovalport dyno. I was expecting the you might have a chance.....but to no avail since you won't dyno.
Who knows, maybe you're just a good driver with a tailwind and your engine really isn't putting out any serious horsepower.
Either way you'll get kudos from your engine build our your driving. You won't get both until you prove both.
#1355245 08/16/05 01:28 PM
Redneck Troll
Redneck Troll
Originally posted by DemonCRY:
snif whaaaa boo hoo cry pout.
Au poo, whaaaaa whaaaaaaaaaaa cry pout snif.
snif???
boooo hooo hooo hooo whaaaaa.
Cry cry cry wail snif snif whaaaaaaaaa whaaaaa.
Soooooooo, does anyone have the pics of the oil drain back holes that could solve the original poster's question?
#1355246 08/16/05 02:43 PM
snif???
LMAO! I want to see Greg dyno also!
BTW, to keep it on topic, I still love my 3.0 hybrid with 2.5L valves.
dion 98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
#1355247 08/17/05 12:59 AM
W
W
Can't say much to that.
#1355248 08/17/05 11:40 AM
....Either way you'll get kudos from your engine build our your driving. You won't get both until you prove both.
Well said, and there are probably a few of us 'lurkers' who agree.
Its' one thing to talk, quite another to actually prove it.
96 LX 3.0L MTX - Black/Tan K&N; 12lb F/W & uprated clutch 2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod; UN-tuned Mod; 3rd Gear Synro-Crunch Mod 280K on the Shell, and 40ish on the Motor... 1/4 mile?? Yeah, it's a fun daily driver...
Page 2 of 2 1 2
