#1355232 08/07/05 06:44 PM
duffgun Offline OP
hello
im an new user on here and i live in engalnd, im currently doing a 3.0 conversion to a 1996 ford mondeo V6 im using my 2.5 heads and an brand new 3.0 short block brought from ford. now i have heard the problems about the oil drain hole but i have talked to someone who says this is not an issue in england is this true and what is the best way round the oil drain problem.
#1355233 08/07/05 08:01 PM
W
W
You're doing a hybrid so you are stuck with what you have. If your heads have three oil drainbacks then you are probaby fine. Run quality oil. It should not cause any more worry than your 2.5L had since it will be oiling and draining exactly the same.
Now if you wanted to improve drainback you can tap holes in the sides of the heads at the rear and run tubing down to the block skirt to drain that oil that could be pooling up in right hand turns. No one has done it but it is do-able.
#1355234 08/07/05 10:29 PM
should have went with the whole 3.0L.
#1355235 08/08/05 01:31 AM
W
W
Why? Did you determine that was the better way to go after doing your hybrid and then doing your complete 3L?
Just wondering.....
Do the hybrid right and you'll be very satisfied and it will not be inferior to the whole 3L.
#1355236 08/08/05 04:02 AM
C'mon Tom, you know....oval ports rule!
Ryan Trollin!
#1355237 08/08/05 06:04 AM
You could use an accusump or moroso oil accumulator with an electric valve. I have a 3L and have one just to be safe, plus it's nice to lube the top end before actually starting the car
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
#1355238 08/09/05 01:47 AM
W
W
Of course they do. I'm running one right now...but only due to convenience and because I was experimenting...and I got a fair price for my old heads which at this point I wish I hadn't sold.
#1355239 08/10/05 12:31 PM
Odd that I come across this thread ... I was just reading on MEG where there are questions of fitment under the hood of a the ST220 manifolds. I'm kind of curious about this, so is this why you're making a hybrid duffgun ... have you heard about this manifold fitment issue ?
1998.5 T-Red on Midnight Blue SVT Build Number 5320 of 6535
#1355240 08/10/05 10:10 PM
There are lots of good reasons that people do hybrids, here are two;
(1) Cost
(2) Maintaining the 'stock' 2.5L look for insurance reasons....
1996 Mondeo 24v 4-door twin janspeed stainless pipe cat by-pass Phase 2 RS bodykit 16" cosworth alloys K&N RU3530 SVT TB/UIM/LIM poly bushings konis/bat springs/bar Pioneer MSDS Indiglos P&P heads 2005 Mondeo Zetec Tdci
#1355241 08/11/05 04:00 AM
(1) Cost
It's not cheaper to do a hybrid.
Both engines look the same and use the same valve covers in the end.
Those are not good reasons.
