Posts: 18 |
hello im an new user on here and i live in engalnd, im currently doing a 3.0 conversion to a 1996 ford mondeo V6 im using my 2.5 heads and an brand new 3.0 short block brought from ford. now i have heard the problems about the oil drain hole but i have talked to someone who says this is not an issue in england is this true and what is the best way round the oil drain problem.
Posts: 5,810 |
You're doing a hybrid so you are stuck with what you have. If your heads have three oil drainbacks then you are probaby fine. Run quality oil. It should not cause any more worry than your 2.5L had since it will be oiling and draining exactly the same.
Now if you wanted to improve drainback you can tap holes in the sides of the heads at the rear and run tubing down to the block skirt to drain that oil that could be pooling up in right hand turns. No one has done it but it is do-able.
See My Mods
Posts: 90 |
should have went with the whole 3.0L.
Posts: 5,810 |
Why? Did you determine that was the better way to go after doing your hybrid and then doing your complete 3L?  Just wondering..... Do the hybrid right and you'll be very satisfied and it will not be inferior to the whole 3L.
See My Mods
Posts: 6,760 |
C'mon Tom, you know....oval ports rule!
Ryan
Trollin!
Posts: 4,970 |
You could use an accusump or moroso oil accumulator with an electric valve. I have a 3L and have one just to be safe, plus it's nice to lube the top end before actually starting the car
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 5,810 |
Originally posted by RTStabler51: C'mon Tom, you know....oval ports rule!
Of course they do. I'm running one right now...but only due to convenience and because I was experimenting...and I got a fair price for my old heads which at this point I wish I hadn't sold.
See My Mods
Posts: 1,177 |
Odd that I come across this thread ... I was just reading on MEG where there are questions of fitment under the hood of a the ST220 manifolds. I'm kind of curious about this, so is this why you're making a hybrid duffgun ... have you heard about this manifold fitment issue ?
1998.5 T-Red on Midnight Blue SVT
Build Number 5320 of 6535
Posts: 347 |
Originally posted by carzyjay: should have went with the whole 3.0L.
There are lots of good reasons that people do hybrids, here are two;
(1) Cost (2) Maintaining the 'stock' 2.5L look for insurance reasons....
1996 Mondeo 24v 4-door
twin janspeed stainless pipe
cat by-pass
Phase 2 RS bodykit
16" cosworth alloys
K&N RU3530
SVT TB/UIM/LIM
poly bushings
konis/bat springs/bar
Pioneer
MSDS
Indiglos
P&P heads
2005 Mondeo Zetec Tdci
Posts: 9,602 |
Originally posted by Ronan: Originally posted by carzyjay: should have went with the whole 3.0L.
It's not cheaper to do a hybrid.
Both engines look the same and use the same valve covers in the end.
Those are not good reasons.
2000 SVT #674
13.47 @ 102 - All Motor!
