#1354610 08/06/05 04:25 PM
W
W
searched in archives for this topic, and couldnt find anything really clear. Will a SVT cluster work in my 95 GL. i know im going to have to run a signal wire for the tach, but whatabout the different spedo wiring?
any help would be great
thanks,
matt
#1354611 08/06/05 05:08 PM
Since you have a 95, it most likely will not work.
Most 95's (early models in particular) do not use a VSS like 96-00 but instead is cable driven.
And unfortunately, because the 95 cluster is the oddball of the bunch, they do not make any aftermarket gauge overlays either.
#1354612 08/06/05 05:17 PM
W
W
#1354613 08/06/05 05:24 PM
Originally posted by whiterain:
these'll work though right http://cgi.ebay.com/ebaymotors/i264-95-98-FORD-CONTOUR-No-TACH-REVERSE-GLOW-GAUGES_W0QQcmdZViewItemQQcategoryZ43952QQitemZ7991794024QQrdZ1QQsspagenameZWDVW
Most likely not. Most manufacturers are not aware of the difference in the 1995 cluster.
The way to check is look at the hole they made for the trip reset. If I remember correctly, the 95 had the trip reset on the opposite side.
#1354614 08/06/05 06:12 PM
W
W
would i be able to modify it to fit? make an extra hole or something
#1354615 08/06/05 06:54 PM
I believe some people have just drilled a hole on in the correct spot. But if you decide to do it, be very careful since you can make it look sloppy very easily.
#1354616 08/06/05 07:20 PM
W
W
alright well i just do that then, thanks
#1354617 08/07/05 02:44 AM
Online Content
Early 95's only. They switched it over to the 'correct' side sometime toward the mid-to-late 95's (as well as a slight change to the console ashtray). The last digit in the trip meter is yellow in these earlier clusters too.
#1354618 08/07/05 06:55 PM
W
W
where can i get the temperature and fan faces at? (and what is the correct name) i remember seeing someone had them but cant remember who it was. you guys know what im talking about?
#1354619 08/07/05 09:06 PM
This is probably the absolute only place to find these. All others are just white overlays with no glow. These are now made thanks to CEG getting enough people with interest to have thise company develop them for us.
HVAC EL Glow Panel
