Originally posted by pupet89440:
For my furture knowledge whats wrong with their rear brake write-up. I'll need to prepare myself for that before hand.
Since you have an SVT, rear pads won't be much of an issue for you to worry about.
The problem with their writeup is that--in reality--the 4-wheel disc setup is completely de-coupled from the ABS option. Selecting ABS on a Zetec model
would not get you 4-wheel discs (nothing could). On top of that, SP implies that MTX's were the only V6 models that got pie plates in the back, which is horribly untrue.
All 1995 thru 1997 V6 models were equipped with 4-wheel discs, regardless of transmission. A few V6/ATX models in 1998 before the identity crisis hit may have been equipped as such, also. But from some point in '98 model year and after, the only way you got 4-wheel discs was to select six pots and a hand shaker.
Since I haven't had to work on the brakes on my SVT yet, I'm currently unfamiliar with the part number specifics, but it should be easy since there's pretty much only one size of pads for the back end of these cars.
Probably what you'll need to do for the front pads is look for the ones to fit a 2000 model...then you're pretty much guaranteed you'll get the right one, considering your prior experience.
