Posts: 227 |
I think my fuel pump has went kaput. I was driving down the road and lost power, coasted to a stop. Car cranks but won't fire up. Fuel pump fuse was blown. Replaced the fuse, still won't start.
My question is this: I found the HOWTO for the returnless fuel pump, but since my 'Tour is a 98 I assume I have a return fuel pump. Do you still get to the return fuel pump under the back seat? What's different with the return fuel pump (other than an extra hose)?
98 Contour V6 MTX, T-Red, 150k mi. Pic
SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin
95 F-150
91 Mustang GT
06 Honda Shadow Aero
Posts: 2,408 |
95 through early 98 return pumps fit through the hole.
It's easier.
Posts: 7,025 |
not sure how much a new stock pump will cost you, but you can pick up a walbro 255 lph for about $90-100 and will work with just minor modification.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 227 |
Originally posted by Rogerm60: 95 through early 98 return pumps fit through the hole.
It's easier.
Cool. I'm gonna let a garage do it since they already have it, but I'll let the guy know in case he still thinks you've got to drop the tank...
BTW, I don't know how I managed to post this in General Mods, I thought I was posting in Duratec Maintainence.
95 F-150
91 Mustang GT
Posts: 1,957 |
well you can drop the tank, if you dont want to drop the tank then you have to cut the sheet metal, dont know if he would want to do it.
NEED AN SVT REAR BUMPER!!! pm me
Posts: 7,100 |
No cutting required.. 95 through early 98 fit through the maintenance hold already in the back seat.
Ray
'99 CSVT - Silver #222/276
Posts: 9,602 |
Originally posted by Ray: No cutting required. 95 through late 99 fit through the maintenance hole already under the back seat.
Just a little freshening up and added emphasis...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 7,100 |
D'OH... Dang you Roger!!! You got me jumping on a textual bandwagon and now look what happened.. they quote ME as wrong, and not you!!!  Ray
Posts: 9,602 |
If thou perpetuates thou most perpetuate properly and precisely. Correct information helps too...
2000 SVT #674
Posts: 7,100 |
Originally posted by DemonSVT:
If thoust perpetuates, thou must perpetuate properly and precisely.
Just a little freshening up, and emphasis.
I know.. a stretch...
Ray
