Posts: 41 |
I removed my 24V emblems from the front fenders and found that there is no clearcoat under them. I removed all the tape and cleaned the surface and now I have a 1.5in X 2.5in square of dull paint on my fenders. I purchased the Hella oval LED side markers but now they are out of the question. Has anyone found a side marker that will cover this area (same size as 24V emblem)? If not it looks like I will have to replaced the 24V emblems and forget the side markers
"They say geniuses pick green"
2000 CSVT- Tropic Green #1261 of 2150
3A Performance exhaust
Kurtz cold air kit
18" Tuner 15 spoke
Koni Sport Kit
Posts: 2,571 |
i belive its the audi a-4 sidemarkers that fit arent they?
Posts: 41 |
Originally posted by ryanblacksvt: i belive its the audi a-4 sidemarkers that fit arent they?
I couldn't find any website that gives dimensions for the A4 side markers. I know that they fit in the hole with limited modification. My main concern is covering the bfugly spot completely
Kurtz cold air kit
18" Tuner 15 spoke
Koni Sport Kit
Posts: 1,516 |
if they don't you can allways use touch up paint and fix the spot
Cameron
98 Black CSVT #2958
Posts: 41 |
Originally posted by SVTatGT: if they don't you can allways use touch up paint and fix the spot
I thought about that.....but I don't want to risk making the problem worse than it is. My paint is flawless with the exception of this new problem and I would replace the emblem before I risked the paint job.
Kurtz cold air kit
18" Tuner 15 spoke
Koni Sport Kit
Posts: 2,978 |
To answer your question: The A4 ones are a rectangle. I had them on my other contour and they fit 'more or less' where the GL badge was. I don't know if the picture will help, but its not a square like the 24V was....
Posts: 6,791 |
I have the Audi A6 sidemarkers. They are not as large as the 24V badge, but pretty close. With the sidemarkers I do not think that there would be a huge issue with the clearcoat.
Posts: 41 |
Originally posted by RawBurt: I have the Audi A6 sidemarkers. They are not as large as the 24V badge, but pretty close. With the sidemarkers I do not think that there would be a huge issue with the clearcoat.
Can you post a close-up pic of your A6 side markers?
Kurtz cold air kit
18" Tuner 15 spoke
Koni Sport Kit
Posts: 6,791 |
Originally posted by bascho: Originally posted by RawBurt: I have the Audi A6 sidemarkers. They are not as large as the 24V badge, but pretty close. With the sidemarkers I do not think that there would be a huge issue with the clearcoat.
Check my sig... If those arent good enough. I'll take one... Very VERY close for you
Posts: 2,571 |
