Page 2 of 2 1 2
F
F
TransSpeedSensor $30, mounted on the side of the transmission behind the left wheel caution: may be rusted in unless you are not in a salty road winter area., Trans range switch about $50 ,mounted on top of trans. Try those before replacing the trans. Before Doing Anything , check for codes with obd scanner. The TPS could also be bad, which is why you should scan for codes. Maybe Autozone can do that. All those sensors work together for the computer that controls the powertrain to make the right decision.
Thanks I replaced the trans speed sensor and that didnt work. I think I will take your advise and go to autozone. What is a " TPS"?
F
F
Throttle position sensor. Definitely visit Autozone. Post what you get for codes, many Ceg'ers know them.
Originally posted by mrtjknapp:
It didnt work. The car when you go to pass someone and you give it gas, it sounds like it comes out of gear and the engine wynes big time. when you let off thr gas its ok. this happens at any speed. any ideas? thanks, mrtjknapp
Are you sure there is enough ATF in the tranny?
E0 Silver Frost CSVT #3095/6535 Alpine CDA-9851
Yes the tranny fluid is fine . I tried to find a trans range switch. There are no listings
F
F
MLP - Manual Lever Position sensor (aka Range Sensor)
That is the proper name. Might be a Ford Dealer part.
thanks Ill try that this weekend
I'd check/replace the following in this order...looks like you alrady done some of this.
0. Pull Codes
1. Check Fluid level
2. Check/Replace TSS - Turbine Speed Sensor
3. Install Transgo Shift correction kit - you don't have to pull trans to do this.
4. If your codes indicate defect elecronic solonoid then you will have to replace the shift solonoid pack as well as instal the shift corretion kit. The key is if you have any codes and can get them read.
If you still have the same problem, then you will probably need a rebuild....replacing perhaps, direct drive drum, install master rebuild kit and replace torque converter.
Change your fluid out if you haven't done a fluid change in awhile.
Page 2 of 2 1 2
