Posts: 7,100 |
Originally posted by FavoriteMystaque: Double check the wiring of each spark plug, if they are in the wrong order or one boot is not snapped on (tricky) you will have a misfire and vibration. Happened to me!
He stated that it ran fine, until he mis-shifted in to 2nd, instead of 4th... unless it caused SUCH a drastic change in acceleration, that it caused two plug wires to swing in the air, and land on the opposite coil, I don't see this being the problem.
Of course, this is assuming that the car DID, infact, run fine before.
Ray
'99 CSVT - Silver #222/276
Posts: 1,456 |
I couldn't find the missed shift 4 to 2 information. Unless you know from another post?
Posts: 7,100 |
his first post "I had a miss shift"...
but, yes, IIRC it was another post that stated 4-2.
Ray
