The temp gauge on my 97 4cyl, MTX Contour refuses to work. I installed a new temp sensor in the housing near the thermostat, also installed a temp gauge I removed from a junk yard wreck. Any other ideas?
Near the temp sensor is a temp SENDER. (they look alot aike. one mounted at a 45degree angle, the other vertically) completely seperate from the sensor, etc, and only controls where the guage reads. This is likely your problem, and had nothing to do with the sensor.
Ray
'99 CSVT - Silver #222/276
Originally posted by Kremitthefrog:I like to wear dresses and use binoculars to watch grandmas across the street.
I just ran out to look at the thermostat housing and only identified 1(one) sensor/sender, it comes out verticle, nothing at a 45 degree angle. Could the sender be mounted somewhere else? On the radiator maybe? Thanks for your help Ray.
