INTRO:
Before I start ordering a bunch of parts, I thought I'd run my plans by the MTX75 gurus on CEG. My 96SE MTX now has 112K on it, the majority of which are city miles.
The MTX still shifts great (I've run the cocktail in it for many years, changing it regularly, and never abusing the tranny), so I don't feel any internal work is necessary, with the exception of a Torsen install (I told the wife it was necessary when I had the transmission out
TORSEN STUFF:
- Torsen (M-4204-F20)
- Carrier Bearings (F7RZ-4221-AC x 2)
- Speedo Gear (F5RZ-17285-AA)
Q1=Is there a "Differential Seal" that I should purchase?
Q2=What sealant do I use to reseal the MTX casing?
CLUTCH STUFF:
- Spec Stage I Kit (Disk/Plate/Throwout/Alignment Tool)
- SVT Flywheel (F8RZ-6375-AA)
OTHER STUFF:
- Rear Main Seal (F4AZ-6701-A)
Q3=Can the Input/Output Oil Seals (F5RZ-7048-AA and F5RZ-1S177-AA) be replaced during the overhaul I'm doing? Without digging through my foot-thick Ford Service Manual, I not 100% sure which seals these really are.
Q4=Are there seals between the CV driveshafts and the transmission? If so, what are the part numbers?
I had hoped that my clutch would hold out until the weather was cooler. Maybe this project will give me an excuse to Air Condition my garage!
(I doubt the wife will go for that "upgrade").
Thanks for any feedback/comments you can provide!
