#1349081 07/31/05 11:24 PM
I spent some time on the 'tour today and it still won't start.
My initial suspicion was the fuel pump. For a quick test, I pulled the fuel rail back so I could watch the injectors spit. They did.
Next I used a tester for spark on the plugs. They all seemed fine. I already replaced the coil, but will be trying the original again, also.
Since the car just decided not to start for no good reason, I suspect the fuel may have been crappy. I sprayed some starter fluid into the TB, but nothing happened. I think part of that may be due to the crappy design of the intake manifold.
So I guess later on - if the weather holds out - I'll go check the timing. Roger mentioned that it's possible the belt could've slipped teeth when I shut it down.
Any other ideas are appreciated.
How many Vs would a VTEC TEC if a VTEC could TEC Vs? The one, the only....FRNKNFORD http://www.westvalleycs.com
#1349082 08/04/05 12:26 AM
Is the timing belt worn or loose?
How does the computer know when to fire the plugs on this engine?
How is the engine compression?
Expose the throttle body when spraying in starting fluid. I once had a Taurus with a no start and turned out the spark was too weak to fire, even thought it looked pretty good in the air.
#1349083 08/04/05 12:59 AM
CEG road warrior
CEG road warrior
Check the starter?
#1349084 08/04/05 03:50 AM
Originally posted by LocoSCZ:
Check the starter?
I will Hector, I promise Now will you quit following me around the board and making me look like more of an ass?
#1349085 08/04/05 03:56 AM
Does it sound different when turning over? That's what I've heard happens when the timing belt jumps.
HTH,
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
#1349086 08/04/05 11:26 PM
CEG road warrior
CEG road warrior
HTH,
BP
Not necessarily.
#1349087 08/05/05 03:03 AM
Perhaps the voltage regulator on the alternator, although its tell tale sign is a clicking noise.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
#1349088 08/05/05 04:42 AM
Not necessarily.
True. If it only jumped a couple of teeth it would probably sound pretty normal.
Mega fuse?
#1349089 08/05/05 11:50 AM
CEG road warrior
CEG road warrior
Not necessarily.
Mega fuse?
That was the weird thing.....my car sounded really weird due to the fact it wasn't starting, which was wearing down the battery, etc. It usually isn't the biggest thing first.....it is possible to jump teeth on the timing belt....but very unlikely. That is why I said check the most obvious thing first; the starter.
#1349090 08/05/05 08:03 PM
that's exactly what I'll be doing this weekend if the weather holds out. I'll make sure to update this thread.
EDIT: I guess I should point out the obvious (mistakenly thought I already had). The starter went from the normal sound to a constant shredding/shrieking sound. It still turns the motor, but probably not very well.
