Page 2 of 3 1 2 3
#1348926 08/01/05 04:38 PM
The outside does look like an SVT UIM. Very smooth. Don't know what could remove PC other than sandblasting though. If there is a chemical for removing PC let me know because it has to be some serious stuff!!!!
#1348927 08/01/05 04:44 PM
Todd a hot tank dip/acid wash should eat right through the powdercoating. Isn't ther a code on the motor to tell if the motor is from a svt? Does the vin come out for a svt? That would be my first checks.
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#1348928 08/01/05 04:46 PM
While a motor check would work, the VIN would be useless, if the car was an svt that had a standard duratec replacement.
Ray
#1348929 08/01/05 04:59 PM
Didn't only SVT's also have black valve covers? I know my SE has unpainted aluminum covers, whereas this engine they seem to be powdercoated.
The part about throwing away the LIM due to excessive build-up is a bit suspect... mine had 1/8" of carbon buildup when I did my first cleaning, yet came off quite easily with about 3 cans of Berrymans. Are people really just that lazy???
Oh, and I know this has nothing to do with engine type, but having spark plug wires laying across the engine like that looks just plain fugly.
-Chris 2000 SE Sport V6 5spd (all stock except for EO brakes)
#1348930 08/01/05 05:36 PM
Nope. Pre98's had black valve covers as well.
#1348931 08/01/05 05:36 PM
Normal iron hot tanks will EAT aluminum though!
The code is on the valve cover. Unfornately that's easy to swap to a non-SVT engine. (it's happened several times before )
Yes the SVT has a unique VIN code.
#1348932 08/01/05 05:58 PM
request a picture of the inside of the UIM behind the TB....non-svt will have a very rough texture and a sharp point where the two main runners merge, the svt's are far smoother and thet ridge is knocked down by the extrude honing.
#1348933 08/01/05 07:02 PM
A fresh can of gel stripper from your local Lowes/Home Depot is capable of stripping powdercoating. It may take three or four applications to do so, but it will do so.
There's a difference between a Euro and a Ricer... Don't cross the line... Anything-Goes C.C. Co-Founder
#1348934 08/01/05 08:00 PM
9
very true...i use valvoline? tb cleaner and it leaves stains on my uim..i could see too much of it taking some of the finish off...just have him pull the tb..the egr passages are different compared to the stock duratec..
#1348935 08/01/05 08:01 PM
9
also that color isnt even close to the stock duratec manifold...its too silver, the stock is a lighter gray with a ruff texture
Page 2 of 3 1 2 3
