Posts: 1,017 |
ok, I've been to home depot and lowes, and I can't find which department copper/brass caps are in. I was probably staring right at them, but nobody knew wtf I was talking about. so the trip wasn't for nothing I got the only 1/2" cap I saw, a galvanized cap. I suppose if I could drill through the top of it, might it work? otherwise, where are these damned caps!
(TH fix for those who couldn't figure it out)
1995 SE
2.5L V6/MTX
187k
Posts: 5,975 |
Uh, Home Depot plumbing section man!
They come in plastic bags and some are loose in small bins.
Posts: 425 |
1998 Ford Contour Se 2.5 litre Silver frost
Posts: 1,017 |
looked there, were none, maybe try another home depot? maybe just look harder...
1995 SE
2.5L V6/MTX
187k
Posts: 2,838 |
I'd go down & look again . My HD has 100's of 'em . They should be right there with the 1/2" copper pipe , the elbows , the joiners , etc . They're to cap the end of a 1/2" copper pipe w/solder . Maybe just ask a HD dude while you're there in the plumbing section . You'll be sayin' "Dag - How'd I miss those ?!?!" LOL !
~~~~~~~ Phil
Black & Tan 2000 SVT Contour #2137 of 2150
35,000 miles & counting !
Posts: 1,017 |
well, sorta, I went back and they didn't have any copper ones. had a couple brass ones, so I guess they'll do, like a dollar more than copper though
1995 SE
2.5L V6/MTX
187k
Posts: 2,838 |
Well , I guess that sorta negates my last post . We were both typing at the same time .
~~~~~~~ Phil
Posts: 3,335 |
Originally posted by platinum_drew: (TH fix for those who couldn't figure it out)
I was wondering what you were all talking about.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 1,506 |
Jeez, I'm trying to picture someone using a galvanized water pipe fitting, knowing how the outside of that sucker is SO much bigger than a 1/2" copper end cap...
Any old/former plumbers here want to talk with him about doing leaded joints on cast iron sanitary drain pipe, and don't forget the oakum?
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 7,025 |
plumbing dept. I worked there for 3 years.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
