Posts: 9,178 |
Has anyone retro fitted a pre 98 clock in a new body style Contour? If so can I see some pictures?
Posts: 9,178 |
Posts: 1,202 |
Originally posted by Pollo_loco69: Hello? Anybody? Not a pre 98 but a 1998 clock in a 1998.5 SVT. Sorry no pics but used the instructions on Contour.org. I used 2 PC sound card standard 4 pin connectors to make my own 8 pin connector to attach to the back of the new clock.
Posts: 9,178 |
Thanks but no thanks Chris......I really need to find out if someone has done the pre 98 clock in a 98 or later. I got one for free and I want to hook it up but the dash is different.
Posts: 2,481 |
Originally posted by Pollo_loco69: Has anyone retro fitted a pre 98 clock in a new body style Contour? If so can I see some pictures? Why would you want this?
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 9,178 |
Originally posted by Pollo_loco69: I got one for free and I want to hook it up but the dash is different.
Posts: 1,195 |
the connections will be the same i believe, but i've not heard of anyone trying it, it should not be too difficult to fit it. Its the making it look decent that could be the tough part....
97 Zetec MTX Sport Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam) Dual Fiamm air horns Mk1 Mondeo Clear corners(and yes I made them fit....) Boston FS80's in the front
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com AIM: AphexTwinGrin
Posts: 9,178 |
That is what I am worried about. I want to make it look as stock as possible.
Administrator
Administrator
Posts: 4,527 |
check the FAQ, the how-to should tell you all you need to know. Unless something totally wierd is going on here, but I doubt that
It's all about balance.
bcphillips@peoplepc.com
Posts: 9,178 |
Rara the pre 98 clock is different from the 98 one. That is why I am asking the question.
