Posts: 1,238 |
Originally posted by gotapex: Originally posted by warmonger: Originally posted by gotapex: Wired pump to get power directly to the fusebox, and grounded it to the chassis. Now getting full voltage to the pump. Only using the thin stock wire to handle the signaling.
Picked up a PLX R500 wideband O2 to monitor the AF and see how much boost we can run.
http://www.plxdevices.com/R-500_productinfo.htm
Fuel pressure up to 55 psi, and AF remains at 11.2:1 or below at 13 PSI at 7000 rpm.
Went to an airfield with a magazine (not sure I can name them yet). It was 103 degrees F, absolutely horrible for turbocharged vehicles. It ran 0-60 in 3.6 seconds, quarter mile in 12.2. Pretty disappointing, but not too surprising.
Wow! Nice if you asked me. You may want to raise that fuel ratio though to at least 12.0-12.2:1 Unless those heads are significantly different than ours, the combustion properties should be the same and 12.2 to one will yield significantly more power and still be detonation resistant if your intercoolers are working properly. I ran 12.0-12.2:1 just this weekend at 14+ psi of boost and nothing happened to the engine but gargantuan amounts of power!  I wasn't ready for that much boost yet so I turned it down but the point is I have stock everything in my 3L block with 10:1 compression, and nothing happened but the tires spinning out at 65-70mph when the boost came back on. Tune it slowly during the lean out process of course and try 11.5, 11.8, 12, 12.2 and see how it goes. Should do it on a dyno so you can see if the torque levels start to fluctuate or get jagged as a sign of getting close to preignition. You shouldn't get anything until 12.5:1 or higher in my experience.....on this engine that is. Good luck with it.
I absolutely agree. We're running too rich right now. I'd ideally like to be right at the 12:1 mark or so. I'd say a little bit rich is ok just for safety, especially with this horrible west coast 91 octane gas.
Next up, we need to tune the boost levels up. Twin GT28R turbos can definitely operate higher than 13 psi before efficiency issues.
The shop that's doing the tuning is getting a dyno in soon. All the dynos I can possibly stomach are coming.
I'm guessing the next issue will be the tranny. Apparently, during heavy sustained roadracing, torque levels about 400 lb/ft become an issue.
Enter> Terry Haines  -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 5,810 |
What?? I don't even think the Noble uses a MTX75.
See My Mods
Posts: 1,238 |
Originally posted by warmonger: What?? I don't even think the Noble uses a MTX75.
Oh really. My mistake.  -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 1,322 |
Originally posted by tropictour: Originally posted by warmonger: What?? I don't even think the Noble uses a MTX75.
The website says Getrag 6 speed.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 316 |
Tomorrow, it's off to the track (roadcourse, not dragstrip). C6 Z06 will be there, as well a twin turbocharged G35 Coupe (with about $130k worth of mods). There will be a few other misc cars too, like a Charger SRT-8, supercharged Scion tC, and some other things I think.
Posts: 375 |
Originally posted by gotapex: Tomorrow, it's off to the track (roadcourse, not dragstrip). C6 Z06 will be there, as well a twin turbocharged G35 Coupe (with about $130k worth of mods). There will be a few other misc cars too, like a Charger SRT-8, supercharged Scion tC, and some other things I think.
Take pics... LOTS and LOTS of pics...
Esp that twin blown g35.
96 LX 3.0L MTX - Black/Tan
K&N; 12lb F/W & uprated clutch
2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod;
UN-tuned Mod; 3rd Gear Synro-Crunch Mod
280K on the Shell, and 40ish on the Motor... 1/4 mile??
Yeah, it's a fun daily driver...
Posts: 5,600 |
Hmm, sounds like some worthy opponents! Let the duratec beat downs begin!
Black 1998.5 CSVT
Posts: 6,106 |
Chop some heads off!!
Mark
2000 Black CSVT
Posts: 127 |
Yes I would like to see many pics of those cars in your rearview.
Cougar V6 MTX: GMK Carbon Fiber Cold Air Intake : SVT UIM : SVT LIM : SVT TB : MSDS Headers & Ypipe : TruBendz 2.5" Borla Single Exhaust : Soild Front Motor Mount : & more
Posts: 1,246 |
yes, take Lots of Pics!!
