Page 2 of 2 1 2
#1343558 07/31/05 05:02 AM
U
U
hey ButtonPuncher, were you able to get those frpp flow specs available yet? I could really use them. thanx again
99 ATX Contour 130k w/ a 21k tranny freshly installed Secret Project in the works
Originally posted by unknown:
Never argue with an idiot, ppl may not be able to tell the difference between you.
#1343559 08/01/05 12:54 AM
Sure!
From the '05 FRPP Catalog:
Lift - Intake Flow - Exhaust Flow (SCFM)
.050 - 38.0 - 32.8
.100 - 80.7 - 74.9
.150 - 119.1 - 109.1
.200 - 153.7 - 144.6
.250 - 181.0 - 167.9
.300 - 193.0 - 186.0
.350 - 204.8 - 188.5
.400 - 214.0 - 193.1
.450 - 220.3 - 195.2
Please keep in mind that the FRPP flows MUCH more than a stock Zetec head. From Ford's dyno numbers, a stock head put out 125.7HP@6k, the FRPP head with stock cams, a FRPP intake, and FRPP header put out 161.5HP@7k. Putting in Stage 3 FRPP cams bumped that to 175.9HP@7k.
HTH,
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
#1343560 08/10/05 12:50 PM
U
U
ok thanks now another question, isn't the max for a zetec motor around 6k, how would you get it up to 7k? I guess you'd have to reprogram the ecu?
#1343561 08/10/05 11:53 PM
Stock redline is at 6750. Probably could go to 7k-7200 fairly safely without mods. I don't know what the fuel cutout is on a mtx, but probably a bit higher than the "redline". But I'm sure you'd be putting a programmed chip on if you're putting cams in anyways.
Page 2 of 2 1 2
Moderated by  Loco4G63
