Posts: 9,602 |
Originally posted by Pre98: DemonSVT built one out of a trash container for sakes.
Hey now. That was mid 14 second trash can mod.
It's cheap plastic insulated board now and does under mid 13's.
FREE WHORAGE
More pics on my site...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 624 |
Your screenname should be McGuyver!
I don't "mod" I just fix what breaks!
98 CSVT #2527 T-Red (Limping)
98 CSVT #2228 T-Red (Donor)
98 SE Sport ATX V6 (Running again)
If swimming is good for your figure, explain whales to me!
Posts: 9,442 |
All that from a trash can!!!!! I'm in!!!!!
Posts: 1,746 |
Originally posted by Obie1: Your screenname should be McGuyver!
You should be hit with a rather LARGE stone. It's MacGyver
2000 Contour SVT
SF - #542 of 2150
Posts: 36 |
is the MAF adapter a must have or the filter wont fit on? and is there instructions for this maf adapter or is it basically common sense once i get it?
Posts: 1,746 |
Originally posted by racerm515: is the MAF adapter a must have or the filter wont fit on? and is there instructions for this maf adapter or is it basically common sense once i get it?
You need the MAF adapter. That is what the Filter is clamped too. It's basically a common sense install. You'll see where and how the adapter goes on when you take off the old filter and housing. It's pretty easy. When you get the filter it will look like th part where the clamp is, is too big for the maf adaptor (youll see what i mean) but just keep tightening it and it will be just fine.
2000 Contour SVT
SF - #542 of 2150
Posts: 624 |
Originally posted by posthuman63t: Originally posted by Obie1: Your screenname should be McGuyver!
I don't think that Richard Dean Anderson himself would be that upset about it, unless you are Mr Anderson!
Posts: 1,746 |
2000 Contour SVT
SF - #542 of 2150
Posts: 36 |
hey when i reomve my stock air box to put in the new filter what do i do with the plug that is currently going into the air box? because once i remove the air box there wont be a place for that plug to go
Posts: 4,155 |
I shot you a PM, racer.
