I am removing the airbag on a 98' Mystique to check the clockspring (cruise not working). Which size screws are the 4 that hold the assembly? It is really hard to see behind the wheel. I believe there are 4 hex screws, right?
98' Mystique, 2.0L Zetec 220k and running like new
This thread might help
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=766764&Forum=trouble&Words=airbag%20loose&Match=And&Searchpage=0&Limit=25&Old=allposts&Main=765115&Search=true#Post766764
There were also some previous threads about clock springs (and horn not working). If you do a search, I am sure you will find it.
