#1341615 07/22/05 08:36 AM
E
Ernie Offline OP
E
My cruise control controls no longer work, checked all fuses under steering column and in power distribution box. Any ideas other then start checking every wire possible?
1999 Silver Frost CSVT stock for the time being.
#1341616 07/22/05 12:06 PM
the most common problem is the unit itself. it is highly unlighly that any of the switches or wiring has failed. if you have a second contique or have another ceger close by or a junk yard try switching units.
also the ford service manual has a pinpoint test procedture for the cruise control
#1341617 07/22/05 12:16 PM
2
Is the hook that pulls the throttle still in one piece? They crack and pop off. Mine has been glued together about 5 years now.
#1341618 07/22/05 12:45 PM
hey im having the same problem in my 98 csvt... what fuses should i check and where is the control unit located and how do u know if its bad??? i'd take it to ford to have them service or look at it to pin point the problem but how much do u think a test like that will run me??? n how on the money is it at figuring out the problem??? let me know
thanks
jason
#1341619 07/22/05 12:50 PM
thanks
jason
should tell you in your owners manual if you have it. to answer the first question above check you connections to the cruise control and the fuses if not you may have to replace the switch.
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
#1341620 07/22/05 02:25 PM
i have no manual thats my problem.... so can any one help here
jason
#1341621 07/22/05 02:34 PM
jason
Try this for the owners' manual
www.fleet.ford.com
