Taasman Offline OP
I just repalced my front wheel bearings and front struts on the front of my car...not that bad a job, I just used standard gas charged struts from canadian tire...that BTW I only paid for one cause the girl on the til had a brain cramp and only scanned one of them..LOL. Now the back are pretty bad as well and clunkity clunk all the time...so Im going to do the rear as well. My question is what am I looking at doing the rears? I want just a standard stock suspension nothing flashy...just a decent ride. What do you recomend going with the same gas charged? and should I replace anything else? Like I hear there is some other bushings and crap back there I should look at replacing?? What kind of job doing the back? and what to look for??
Thanks Guys.
you should change your sway bar end links and maybe bushings as well, and maybe your strut mounts, and that's pretty much it. good luck.
1998 Ford Contour Se 2.5 litre Silver frost
yes I would match the struts to the back so the ride is the same and not different
otherwise it is about the same as the front in terms of work
