Posts: 1,651 |
So who ever has this bar, do u guys feel any diff when cornering?
I reject your reality and substitute my own.
Posts: 6,910 |
Originally posted by Arhethia: So who ever has this bar, do u guys feel any diff when cornering?
as it has been posted the rear bar makes the most difference, but I did go to my hs parking lot and was cutting corners around the islands at near 30, car felt like it slid around the corner, but not out of controll, you could see where the tires rolled over some and this was with the 17s and W rated tires
- 95 Mystique LS - Zetec/5spd
Posts: 1,303 |
depends on who you ask. i noticed a difference, whether it was good or not really I'm not sure as I'm no expert, but I thought the body felt stiffer and enjoyed the bar. after taking it off the car rode a little smoother around but felt a little more roll-y
Goonz12: <---tries on mommy's cloths
Posts: 508 |
I'm very happy with my OMP (well wanted yellow but guess there red now  ) It does make the ride feel stiffer. I have a rear BAT strut bar on the way, and a mid frame brace coming as well. I installed mine on the GL which has the Zetec, which I believe can't be done without removing the stock air intake setup and replaceing it with a short ram or cold intake setup. JD
JD a.k.a Fingers
"Don't Panic"
'98 Contour GL 2.0L VCT ATX 88k
'98 Contour LX 2.5L MTX 120k
Street racing can kill
just less of a chance with a 2.0
Posts: 77 |
Here are some pics of mine. As I said, it is tight on the AC line and in turn the brake fluid. There doesn't seem to be room to move the AC line behind(toward the passenger compartment) the STB, so it ends up pressing right against the brake fluid. I was hoping that it was an install problem, but now I'm wondering if the bend in the bar has changed slightliy...
I'll be trying brapple's advice and looking for a bracket holding the AC line, just haven't had time to do that yet. Maybe that'll fix the problem.
99 Sport ATX
1 owner, 94k
Mobile 1 since 1k
Mods:Sony MD Player, Sony XA-300 expansion unit,
Sony CD Changer, XM Radio, 350Watt Alpine Amp,
2 10" Subs, Remote starter, glow gauges, K&N filter,OMP Front STB, SVT Exhaust(no res.)
Posts: 6,910 |
now it makes sense, I thought you were saying the bar was close to the brake fluid resivor cap
yes the OMP bar is truely made for the zetec as I stated as it doesn't have the AC line there, they both want to be in the same spot. if you remove the plastic nut on the bracket i noted in the pic below it will allow the ac line to move back over the brake booster and out of the way, reference pic I posted before
again you might want to move the throttle cable as at the moment is it behind the ac line and moving th eline back would pull the throttle cable back also
should work perfectly
Posts: 540 |
I have the same issue - the A/C line sits right on top of the reservoir cap. My work around is just to unbolt the bar where it bolts (with the single bolt) to the cap on the strut. Just do one side and lift up and voila!
'98 SVT Red/midnight blue - a few mods
E0 wheels for sale - PM me
