#1340007 07/20/05 05:43 PM
Lately, I've been hearing a chattering sound while driving. While on the road I can really only hear it when driving along a solid object such a houses or a wall. It's been going on for about a week and I think it might be the timing chain. Yesterday, I was revving the engine a little bit to see if I can here it and sure enough it was there. I think it might be the timing chain but I'm really not sure. it only does it when the car is warmed up. I have a feeling this won't be a cheap/easy fix so before I bring it in I want to get some advise. thanks guys
98.5 SVT FOR SALE $5000
#1340008 07/20/05 06:56 PM
I think I have the same issue. It clanks from idle to about 3k rpm at a constant rate depending on RPM?
1996 Contour V6 2.5L 24V 5 speed Shift knob: pilot Nickel Metallic Millennium Plus Series Foglights: Pilot Pictures: http://www.cardomain.com/memberpage/787584
#1340009 07/20/05 08:55 PM
This must be a very sensitive subject. Nobody seems to know anything about this matter. I know you all are out there, help a cegger out
#1340010 07/20/05 09:00 PM
its been discussed before, but no one ever has an anwser
#1340011 07/20/05 09:14 PM
Simple fact of the matter is, we can't hear it for ourselves, so it's difficult to diagnose over the web. Could be rod bearing, main bearing, chain tensioner, cam pulley, or even something as cheap & simple as some loose catalyst material from the precats rattling around in your exhaust.
I'm inclined to think it's the latter, just because I'm an optomist.
#1340012 07/20/05 10:56 PM
True. Unless the engine has lots of miles or has been overheated, the timing chain is seldom prone to problems.
#1340013 07/21/05 04:47 PM
Hey Guys, FYI, contours do not have timing chains they have timing belts
Col. Bill Evans CAF (ret) 98 Contour GL Zetec ATX (totally stock) Color-Willow Mist 104,XXX Miles
#1340014 07/21/05 04:52 PM
can anyone else back that up? I suppose that's good news then cause what I was hearing sounded more like a chain. I guess if I don't have one, I can look somewhere else. I like the loose catalyst theory. I did have an engine light about a year ago that read a bad bank one cat. never did anything about it tho, passed smog test and everything. Hopefully this is the problem and it's an easy fix. well, relatively easy.
#1340015 07/21/05 04:55 PM
V6-Duratec-Timing Chain
I4-Zetec-Timing Belt
Here are some pictures.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=v6maint&Number=1005094&page=0&view=collapsed&sb=5&o=7&fpart=1
#1340016 07/21/05 05:01 PM
cancel that. Crap
