Posts: 759 |
Okay, getting my Koni's and doing them this weekend. When I replace my struts I am most likely going to mess up my alignment. Here is my problem.
Right now my alignment sucks. Ive accidentally worn the inside of my drivers side front tire down to bald. Its starting to do it on my replacement tire.
If I get an alignment today after work, and go replace my struts ( messing up the alignment) will they honor their 6 month warranty?
Can they tell if it wasnt road conditions that messed the alignment up (we have horrible roads here in Texas)
Also, do Pep Boys install customer struts? I can do the rears I just dont want to do the fronts.
E0 #4384 of 6535
Born Jan. 9 1998
My SVT from the ashes
147,466 miles, purchased Nov. 2002 @ 76,559 miles
Posts: 6,791 |
Originally posted by CSVT985: I just dont want to do the fronts.
To me they look easier then the rears...
Posts: 1,609 |
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 6,760 |
I'd rather have a retard install my struts than someone at Pep Boys...just my .02 for the day. Originally posted by CSVT985: Also, do Pep Boys install customer struts? I can do the rears I just dont want to do the fronts.
Ryan
Trollin!
Posts: 759 |
I've heard that the rears are by far the easiest. Maybe I was wrong. I guess I will do it all myself. It will probably take me Saturday and Sunday...but hey its free!
But what about the alignment? Do you think they will honor the warranty or just say no because my alignment will be so far off?
E0 #4384 of 6535
Born Jan. 9 1998
Posts: 1,356 |
Rears are definitely easier... All you do is unbolt the two bolts that hold the strut hat into the strut tower (look up in the tower, from the wheel well and you'll see what I mean). Unbolt the strut-knuckle pinch bolt and drop the knucle down, leaving everything else intact... My struts/springs in the rear were so bad that I pulled them out effortlessly. One coil was completely broken on one side...  The fronts, you have pull the knuckle out of the ball joint, which was a pain for me, if you live up north or anywhere they use salt in the winter be sure to use a good penetrating oil on the bolts/nuts that you will need to remove. When you put it all back together be sure to use something like Anti-seize or lubriplate... So if you ever have to do the job again, you won't have to fight to get the bolts out...
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 759 |
I just wish someone had pictures. It would make it a whole lot easier.
Im will take lots of pictures and hopefully this will help others.
E0 #4384 of 6535
Born Jan. 9 1998
Posts: 21,197 |
Hell no.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 21,197 |
Originally posted by RTStabler51: I'd rather have a retard install my struts than someone at Pep Boys...just my .02 for the day.
-'96 SE MTX 3L
Posts: 6,791 |
Hell no.
Well sweet then... I know how to do the fronts, but didnt pay attention to the backs... If you say its easier, then I'll believe you and lower my own car. Woohoooooooo
