Posts: 9,602 |
Originally posted by Kremithefrog: So when you coming to SDR or Cecil warmonger? I wanna see you run my friend's srt4 (just for my enjoyment, I like both cars). As I said, he ran 13.4 with just boost controller, intake, and motor mounts. Now he has exhaust, waste gate, better bov (I don't know if the mopar bov handles the higher boost correctly), and stage one is in the mail. Should be a pretty close race.
Shouldn't even be close to a turbo 3L. (350/350) Honestly.
As for the VBC, without programming adding more boost to the SRT-4 doesn't gain much of anything. Many dynos to prove that. The stock computer just retards timing when the boost is out of the stock range.
Cecil must be an insanely fast track because 13.4 is almost a second faster then he should run. If that's the truth I bet I'd run 12's at Cecil. Honestly I am not kidding in the least.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 6,760 |
Cecil is the 'fastest' track on the east coast.... Originally posted by DemonSVT:
Ryan
Trollin!
Posts: 5,810 |
I've got no problems with it. However, I am mystified by a 13.4 with just a BC. Does he have different tires?
See My Mods
Posts: 508 |
Originally posted by warmonger: I've got no problems with it. However, I am mystified by a 13.4 with just a BC. Does he have different tires?
SRT-4's run 13.9-14.1 stock in the 1/4 mile. All the numbers i have seen show that.
http://www.albeedigital.com/supercoupe/articles/0-60times.html
Posts: 432 |
theres no way an even modded 3L would run with a srt my friend has one with minimal mods and ran a 13.0 with a crappy launch, and on top of the stock tires.
Posts: 6,106 |
Originally posted by SvtEdwardo420: theres no way an even modded 3L would run with a srt my friend has one with minimal mods and ran a 13.0 with a crappy launch, and on top of the stock tires.
You my friend must not visit this site often. You do realize that there is a member of these boards that has run a 13.4 in his N/A 3L, right? Show me ONE(1) SRT-4 that has run a 13.4 STOCK. And what are the "minimal mods" on your friend's 13.0 SRT-4? Your false claims are going to be chewed up and spit out on these boards unless you have more detail than that.
Mark
2000 Black CSVT
Posts: 508 |
SRT-4 is extremly quick car yes, but 13.0 with minimal mods and crappy launch ? ? LOL
Posts: 9,602 |
Originally posted by SVT25: Originally posted by warmonger: I've got no problems with it. However, I am mystified by a 13.4 with just a BC. Does he have different tires?
If you want to "bench race"
...per... Motor Trend (even using their killer correction factors} 2004 SRT-4 ~ 6.2 ~ 14.4 @ 100 2003/4 SRT-4 ~ 5.7 ~ 14.0 @ 100.5 (preproduction 04 model before it gained weight) Preproduction SRT-4 ~ 5.5 ~ 13.9 @ 101 {this car had Stage 1+ and was tuned though}
However these numbers are by PROFESSIONAL DRIVERS and corrected to the optimum conditions & sea level.
There are several folks here I trust that state "REAL WORLD" times right in line with what I've seen. I admit our track here is a bit slower then most but it's where I have run against other cars.
2000 SVT #674
Posts: 432 |
he has a 3" down pipe with dump, wires and plugs, motor mounts new bov and a bigger IC and a dollar boost controller. thats it , im not making flase claims, so back off. he has stage 2 now with a afac, and just got it tuned but hasnt put down a time so ill let you know when he does.
Posts: 6,106 |
what are is the stock boost setting on a stock SRT-4 turbo? What is max boost with the same turbo? If you can crank the stock turbo up by say, 8psi, you're making a LOT more power than stock, which should cut some significant time off of your 1/4 mile. But I really don't know much about the SRT-4 factory boost levels and what they are capable of.
Mark
2000 Black CSVT
